Bio ethanol
Old Jan 10, 2021 | 04:20 AM
Xk646's Avatar
Default Bio ethanol
Hello, do you have xk mounted on ethanol? I bought mine an ecu reprogramming was done on it
Old Jan 10, 2021 | 06:48 AM
jahummer's Avatar
You’d likely need a better pump, larger injectors and a return fuel line.
Old Jan 10, 2021 | 07:07 AM
Xk646's Avatar
She is already in bio ethanol it was to know that other people rolled in ethanol
Old Jan 10, 2021 | 03:05 PM
jahummer's Avatar
What percentage are you using? What modifications did you make to the car to run ethanol?
Old Jan 10, 2021 | 03:55 PM
Xk646's Avatar
100% ethanol reprogramming of the ecu of the cartography
Old Jan 10, 2021 | 04:14 PM
Stuart S's Avatar
I noticed that Xk646 is in France. Why make the switch to 100% ethanol? Is it because ethanol costs less than gasoline? Are the catalytic converters affected?
Old Jan 10, 2021 | 05:41 PM
jahummer's Avatar
There are a few issues with switch to ethanol and not changing anything else, such as damage to seals and fuel pump, lack of fuel return and likely the injectors won’t be able to keep up either.
Old Jan 10, 2021 | 11:14 PM
Xk646's Avatar
From urban legends about ethanol to the modern engine effectively brings together maintenance and cold starts
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAQAAAA ngNWGAAAA/0lEQVR4AYXNMSiEcRyA4cfmGHQbCZIipkuxnJgMStlMNmeyD2d wmc8+sZgxYJd9ErIZFHUyYYD7fkr6l4/rnvmtl7+KitrqV/fq2Y5eLY3Z9S48eRLe7BmVZ9qhTLhQ0algzZWQOVKSsCF8OjAn wbxDTWFDUhPK/jMr1H6HE/IqRky2DyvCefuwItwZzodVoYRiLqMkVCXrwpJ9twZ+sgfDYEFY l8wIWxZ9uFf7zkallxlJh4YrLGsKjZRx7VGHhLqwgFUN45DGdb 8MeXGpgB4ABZdeDcpZEY51A+hyLKz4S1W4MQWm3AibWtgWmk6d yISa1pSdyWTOlLXVp0+eL9D/ZPfBTNanAAAAAElFTkSuQmCC[/img]
Old Jan 11, 2021 | 07:16 AM
guy's Avatar
guy
An opinion:
https://e360.yale.edu/features/the_c...or_environment
Old Jan 11, 2021 | 07:24 AM
Xk646's Avatar
Honestly, I don't care and trying to make people feel guilty is useless otherwise you have to drive in a smart or electric but electric xk there are none
Old Jan 11, 2021 | 10:46 AM
jahummer's Avatar
What is the reason for running ethanol rather than petrol?
Old Jan 11, 2021 | 10:49 AM
Xk646's Avatar
I buy it like that, and the liter in France gasoline is expensive
Old Jan 12, 2021 | 04:48 AM
Stuart S's Avatar
Why is ethanol so cheap in France? Because it's really Russian rotgut vodka smuggled through the Nord Stream 2 pipeline into Germany, and then smuggled into neighboring countries.
The ringleaders of this Russian criminal enterprise are known as Oiligarchs.
Old Jan 12, 2021 | 05:24 AM
Xk646's Avatar
In France it is less than 50% compared to gasoline
Xk in DXB
Sep 30, 2020 06:05 PM
trkyam
May 13, 2019 10:04 AM
BaDAss03STR
Sep 10, 2008 09:17 AM
BaDAss03STR
Sep 10, 2008 02:57 AM
