Boost numbers 5.0 vs 4.2 Xkr supercharger
Old Jul 27, 2020 | 10:35 PM
AlexJag's Avatar
Sponsor
Default Boost numbers 5.0 vs 4.2 Xkr supercharger
Anyone know what boost numbers are supposed to be for 5.0 cars ? ?
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Jul 27, 2020 | 10:43 PM
Stuart S's Avatar
Did you check the 5.0L Workshop Manual in the Stickies?
Old Jul 28, 2020 | 01:19 AM
AlexJag's Avatar
Sponsor
I usually check it with torque pro app , so it might not match the manufacturer exactly . Il check the workshop manual
__________________
Old Jul 28, 2020 | 10:31 AM
Cee Jay's Avatar
By only checking with a quick glance once in awhile, I don't think I've managed to get any higher than somewhere in the 7psi range. Maybe I have though, as I rarely look at the boost gauge. I've also never bothered to check the stored data.
Old Jul 28, 2020 | 01:22 PM
AlexJag's Avatar
Sponsor
That that makes sense then. I was kind of wondering because it appears that 4.2 produces higher boost numbers Even with both cars having a pulley 4.2 is still higher. Around 8.5 max for 5.0 and 11 for 4.2
__________________
Old Jul 28, 2020 | 03:29 PM
Cee Jay's Avatar
Well, maybe I should get a smaller S/C pulley. They are the same blower models, right? If'n 11 works on 4.2, then it should work on the 5.0...... UNLESS the Volumetric Efficiency of the 5.0 is superior to the point that there is less pressure accumulated because it all goes where it should.
So many things to ponder.
Old Jul 28, 2020 | 05:07 PM
jahummer's Avatar
The 2009 and earlier Jags used the roots M112 and the 3.0 and 5.0 cars use the TVS R1320 and R1900 respectively. Your car would benefit greatly from a small pulley as the TVS blowers are significantly more efficient than the roots style.
Old Jul 28, 2020 | 10:41 PM
AlexJag's Avatar
Sponsor
Just make sure you get proper tune to adjust boost otherwise ECU will keep it near stock numbers
__________________
Old Aug 2, 2020 | 09:25 PM
Airbornecat's Avatar
Sorry, I posted wrong area
Jim Raban
Jan 22, 2022 12:04 PM
Jim Raban
UK & Eire
Feb 26, 2020 07:48 AM
SLazz
Feb 27, 2018 03:46 PM
1 of 19
Dec 17, 2015 11:26 PM
Wolfy
Sep 14, 2015 10:52 PM
