Brake Dust Barrier product
Old Jan 8, 2014 | 05:22 PM
richzak's Avatar
Default Brake Dust Barrier product
FYI:
Last month I bought a spray product for blocking brake dust:
Amazon.com: Meguiar's Hot Rims Brake Dust Blocker: Automotive Amazon.com: Meguiar's Hot Rims Brake Dust Blocker: Automotive
After one month of use and a few hand washes, I would highly recommend this product. It is made by Meguairs. When washing the car, the wheels are so easy to clean and the water just beads up like a good car wax.
Only caveat is, make sure wheels are 100% DRY, before spraying on the Meguiars Hot Rims Brake Dust Barrier. This is EXTREMELY important. I suggest to wash the wheels one day and apply the product the next.
I give this product by Meguiars a 10 out 10 rating and the spray is priced at $11.23 at Amazon.
I am sure you could buy the spray locally at any auto parts store. It is well worth the money and giving it a try.
It really does work.
Hope this helps end some frustration on keeping wheels clean from brake dust.
Old Jan 9, 2014 | 06:46 PM
jahummer's Avatar
I have used this product as well as the Armor All version and concur that it works very well, especially with Brembos & chrome wheels I had on my Super V8. I never go with out it.
Old Jan 20, 2014 | 08:08 AM
Kopavi's Avatar
Old Jan 20, 2014 | 11:18 AM
user 2029223's Avatar
Banned
Shake well. Spray it and forget it.
Old Jan 20, 2014 | 02:56 PM
richzak's Avatar
Originally Posted by Kopavi
The directions on the package only talk about spraying on and don't get into wiping off or buffing. I assumed you would apply like was and wipe off and buff. Are you suppose to wipe off after spaying or just apply the spray and let it dry? Thanks
Yes, if your using Meguairs Hot Rim Brake Dust Barrier, you need to make sure the wheels are cleaned first, washed and COMPLETELY DRY. Then just spray on and let dry. If the Hot Rim Dust barrier product mixes with water, it will leave a white residue, which you do not want.
I suggest to wash one day or early AM, then let wheels dry. Water build up is usually in the lug nut holes. Blow the water out of the lug nut holes with an air compressor.
The Meguiars Hot Rim Brake Dust Barrier product works great. I have gone through 2 hand washes so far and the wheels are very clean, with virtualy no indication of any brake dust buildup.
For $11.00 per can, it is well worth the cost. I suggest that you at least give the product one try.
Works great on hypersilver wheels or darker wheels, BUT will leave a very slight matte finish on chrome. The chrome still looks great however.
It really blocks brake dust and just overall dirt.
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
Jefro
Sep 15, 2015 01:44 PM
XFR_Gold
Sep 2, 2015 12:24 PM
