Buying an XK with a replacement motor good or bad?
From what I've read, there have been 3-5 (not sure the number) attempts to redesign the water pump and I believe the last iteration is a fix. Others will have to provide part numbers.
There are a few solutions for the lack of gauges, none of which are optimal but all are workable. I would drive it as Shemp and Ranchero suggested. They do (replacement engines) often feel a little off and you should drive another 5.0 to compare.
Matt Harrell (09-07-2017)
#28
If you have an Android phone you can buy an OBD reader and a the Torque app for less then $30. Then you will get temperature, voltage and many other readings that you can select to put on the phone. Finally you can buy a magnetized clamp that will fit into the CD slot for less then $15 on either Ebay or Amazon where you will find the OBD reader as well as the Torque app. As a bonus then you can use Wayze or Google maps on a regular basis and not worry about updating the DVD GPS.
Also I think driving both the engine swapped vehicle and another unswapped vehicle is a great idea. By the way, you may want the selected car subjected to a pre-purchase inspection for both mechanics and body damage. Total cost for both should be less than $500-600.
1. The OBD/Bluetooth interface is always on and drawing power when it it plugged in. Even with the car shut off it draws power.
2. If I want to monitor the engine temperature I have to remember to start the app on my phone and connect to the OBD reader whenever I get in the car.
3. I use Google maps for navigation on my phone. If engine temperature is being displayed, I can't see the map.
4. When connected to the Bluetooth OBD reader it cannot connect to the car's Bluetooth hands free phone system.
For those reasons I opted for a dedicated temperature display that turns itself off when the car is off.
#30
ralphwg (09-09-2017)
#31
The OBD socket on my 07 XKR still supplies power after the car has shutdown. I have just leant in through the open window and plugged my wifi ELM327 box in to the socket and was greeted with a red flashing led and that is on a car that hasn't been touched for 2 hours.
#32
Received 1,902 Likes
There are units, including the wifi unit I have, that shuts itself off a short time after the ignition is turned off. Just read the features of the unit before purchasing.
#33
I am sure the X50 is not for everyone. It works for me and addresses my concerns.
I do have wireless ELM327 interfaces in my other cars for reading or clearing any codes that my pop up. The other cars all have OEM temperature gauges though.
#34
Matt Harrell (09-08-2017)
#35
#36
#37
A new engine only, and while being installed by a dealership may be an advantage over a Non Jag shop (perhaps), it's still a far cry from a factory install. I've swapped enough engines in my time to recognize there is a difference. Back to Ranchero and Shemp's advice. Drive it side by side with a non lemon car if you can. There's a reason it's going for $21k
Queen and Country (09-09-2017)
#38
Yes. Brand new OEM replacement engine from Jaguar. The dealer replaced the engine and the owner then put on another 12k miles before trading it in at a different dealer.
There was nothing about the motor being replaced on carfax, I figured it out after talking to two different Jag dealers and they both confirmed the engine swap.
Apparently not everything gets on the car fax report.
