Can I use XJL staggered wheels in my XK?
Old Sep 22, 2023 | 01:04 PM
SirJohn's Avatar
Default Can I use XJL staggered wheels in my XK?
Lads, I've been offered some 20 inch XJL staggered wheels, 9 front and 10 rear. Would they fit in my 2012 XK? I tried looking for info in previous posts but couldn't find the answer. Thanks!
Old Sep 22, 2023 | 01:34 PM
equatorial's Avatar
I'm no expert, but-
XJ 20" wheels 9" ET49 and 10" ET46
Source:
https://www.wheel-size.com/size/jaguar/xj/
Using the same website for XK wheels, it appears that some of them were the same size and offset.
Old Sep 22, 2023 | 02:42 PM
Cee Jay's Avatar
Are the lug spacings identical? Hub size identical? I don't know, just asking pertinent questions.
Old Sep 22, 2023 | 03:05 PM
SirJohn's Avatar
I have no answer to that, it has the same number of lugs but I don't really know if the space between them is the same. Will probably have to go and look at them, just wanted to double-check before taking a 30-minute ride.
Old Sep 22, 2023 | 05:53 PM
OzXFR's Avatar
Yep, the PCD (Pitch Centre Diameter) and hub holes (centre bore) are exactly the same.
PCD is 5x108 on all modern Jags, centre bore is 63.4 mm.
ylwiron
Apr 17, 2014 01:59 PM
2011XJLSupercharged
Apr 15, 2014 06:26 AM
viperz06
May 21, 2011 10:31 AM
