Catalytic Converter Gasket
Old May 19, 2016 | 09:34 AM
Rey's Avatar
Rey
Default Catalytic Converter Gasket
My '07 XK has been emitting a intermittent PO00171 code, indicating left bank fuel lean.
More likely it is an air leak. It acts more like an exhaust leak - code pops at low speeds/high vacuum and does not pop at sustained highway speeds. My guess, at this point, is an exhaust leak where the catalytic converter mates with exhaust manifold.
Checking Jaguar parts fiche for exhaust system I do not see a part for a gasket between the cat and exhaust manifold. Does this mean it is a gasketless connection? Is the "fix" merely tightening mounting bolts? Would an aftermarket cat gasket be advised?
If there is a gasket, what is the part number?
Thanks for your advice.
Old May 19, 2016 | 05:29 PM
Rey,
I've moved your question from General Tech Help to X150 forum.
212 Views as I write this and zero replies!
Old May 25, 2016 | 11:49 PM
Jacsun's Avatar
I am not sure about the gasket but this thread from the X100 forum dealt with this issue and may be helpful...including suspect gasoline from a certain supplier!
https://www.jaguarforums.com/forum/x...es-mean-88451/
Old May 26, 2016 | 10:56 PM
NBCat's Avatar
All DTCs are alpha numeric with five places, so the code must be P0171?
What are LTFTs and STFTs? They are a good indicator of what is going on, so post them here.
By 'parts fiche' I assume you mean the JEPC? The exhaust downpipe and catalyst is a taper fit with the exhaust manifold and does not use a gasket or seal.
hisport
Apr 6, 2016 10:23 AM
Nee_the_Bogeyman
Apr 3, 2016 10:41 PM
tigger
Apr 2, 2016 08:56 PM
Rabidfox
Mar 29, 2016 08:55 AM
simeonbalsam
Mar 27, 2016 09:33 AM
