CATS suspension front strut repair
Old Dec 5, 2023 | 03:26 PM
BUBBA79#'s Avatar
Default CATS suspension front strut repair
I have a 2007 XK with CATS and pulled front strut to replace the insulator. The rod seems to have withdrawn or lowered to the point that I cannot compress the springs ENOUGH to finish the final installation.
Any suggestions on how to correct this situation and get the rod at the right length?
Old Dec 5, 2023 | 04:14 PM
kj07xk's Avatar
Had to use 2 sets of spring compressors to get that spring short enough (rented from the local auto parts store). Compress as far as possible with first set, then use second set on the coil openings now at the top and bottom.
Old Dec 8, 2023 | 04:35 AM
steve_k_xk's Avatar
I've done it both ways with a proper floor mounted spring compressor unit and also with 2 sets of spring compressors please be super careful 🙏
Old Dec 23, 2023 | 09:15 AM
kj07xk's Avatar
Originally Posted by majsik
I might be alone with this comment but I found it hard to see what you were actually doing due to hands and arms in the way and some issues with lighting. Not seen these tasks on video before so it’s a very useful resource, for me it would be helpful to take more time and show more detail of what’s being done.
Spring compression is being done while the strut is off the car, so everything is in plain view. Spring compression is to take the strut itself apart to replace a component, usually the damper or isolator. No need to compress it when removing/installing the strut on the car.
steve_k_xk
Aug 1, 2023 03:30 PM
Smonop
Jul 18, 2023 07:03 PM
spalmgre
19
Jun 6, 2022 07:50 PM
Brewster411
19
Mar 25, 2018 01:56 PM
myexcursion
Jul 1, 2017 10:41 AM
