Change your e-diff fluid!
Old May 2, 2018 | 11:12 AM
  #41
Aprilia2012's Avatar
What are your thoughts Cee Jay on the tranny and did you do the E diff change?
Old May 2, 2018 | 11:16 AM
  #42
Queen and Country's Avatar
Originally Posted by Cee Jay
MAKE SURE that the Filler Plug comes loose BEFORE you drain
valuable advice
Been there too, on a low quality domestic differential.
Could not get drain plug loose to save my life, with the limited clearance to get a breaker bar.
Soaking the thread with a mix of atf fluid and acetone for 2 days did the trick.
Old May 2, 2018 | 12:00 PM
  #43
Cee Jay's Avatar
I am embarrassed to say that I still have all the parts and equipment to do both the Trans and the E-Diff sitting on a shelf in my garage, right in front of the XKR. Many other projects have inserted themselves in a higher priority lately. SOON, I hope.
Old May 2, 2018 | 12:05 PM
  #44
kj07xk's Avatar
While informative, that video was painful to watch.
Oh it wasn't that bad. And it was only 7 minutes. Much better than most (maybe all) corporate training videos I've sat/slept through.
Old May 2, 2018 | 01:45 PM
  #45
So did I understand that we are NOT doing a full flush. (Meaning we are not doing the C converter) which means only dropping the pan which should be what? 4 to 6 qts?
Old May 2, 2018 | 03:39 PM
  #46
Cee Jay's Avatar
I'm not going to do a full flush, it seems unnecessary and VERY expensive. May as well have the entire transmission rebuilt since it'd be out anyway.
I have a pan (w/filter), mechatronic (sp?) sleeve and 6 quarts ready to go.
Old May 2, 2018 | 03:58 PM
  #47
Are you doing it yourself or having it done?
Old May 2, 2018 | 04:16 PM
  #48
Cee Jay's Avatar
Since I don't have a lift (yet) I'll have a buddy of mine who owns an indie shop do it while I watch/manage. He's treated me really well for the past 15+ years. Course, I help HIM out with different things also, so that's fair.
Old Oct 3, 2018 | 03:17 PM
  #49
tractioninc's Avatar
Great info in this thread. I never would have suspected the diff for the weird steering feel.
Old Jan 16, 2019 | 07:18 AM
  #50
Feffman's Avatar
Trans and e diff change. I called Jaguar in Tampa today to see what they would charge me to change the transmission fluid and do an E Diff change. It took some time for them to get back with me and they told me they were both closed systems. I asked, what if you had a transmission leak? They said they would replace the gasket and the filter and put in about 8 quarts of oil at $60 a quart. He said there is no scheduled maintenance change for either of those areas from Jaguar. He said that if there is a problem with either one of those, they normally replace them. I told him, that’s not a great option if you’re an owner who’s car is out of warranty. Hey said, I see what you mean. But I checked with the master mechanic here and that’s what he said.
So my question to the forum is Jaguar says neither one of those should ever need replacing. How do you feel about ? A partial tranny change by dropping the pan replacing the filter versus a complete flush? (for a car with 67k) In the old days they said to never do a complete change. My Jag has 67k miles and my was a preventative measure.
What are your thought about this unspoken maintenance need?
2. And if you moved forward, how do you know how many qts does it take for a full change vs just dropping the pan and doing a partial? And how do you check what is in there? Thanks
Was thinking the same on my 2010 XKR with 39,000 as preventive maintenance. I called the local dealer who informed the transmission fluid/filter flush/change was $1,100. I asked him if that was to change the fluid or the actual transmission. Cripes, I was stunned!
Feff
Old Jan 16, 2019 | 09:36 AM
  #51
pauledddy's Avatar
Sorry to revive and old thread...
Does the car have to be running when filling the new fluid as per @jbretthorton's comment? TIA!
Old Jan 16, 2019 | 09:37 AM
  #52
Cee Jay's Avatar
Feff
Had mine done at an Indie Import Specialist shop, cost me about $300 for the labor for a pan replacement. I had already purchased all the parts/fluid for about $130..... so right at $430 (approx) to get mine done. Took just over 9 quarts.
Also, most places advise against a flush, and bad things can happen.
Old Jan 16, 2019 | 10:43 AM
  #53
Feffman's Avatar
So I'm confused on the diff fluid. The Castrol BOT 720 appears, per a previous post, to be a 75W-90 but the specification, again mentioned in a previous post, M2C192A is a Ford spec 75W-140. Can someone clarify what is correct, please?
Feff
Old Jan 16, 2019 | 11:14 AM
  #54
If anyone has trouble finding the Castrol rear diff fluid for the Electronic Differential on the 2010+ XKR.
The RAVENOL J1C1126 Multi-Disc Locking Differential Fluid is a very good choice.
Also those who bicker about Jaguar related issues. This is a review of the above oil from a Porsche owner.
Old Mar 16, 2019 | 06:28 AM
  #55
Ter11's Avatar
Hi all
Not sure if this was already clarified. But I could not find the answer.
Is the E-diff only fitted to the 5.0 supercharged XKR or do also the 5.0 NAs have it?
I always thought it’s only the XKR. But in the January edition of Jaguar World Magazine they mention both, XK and XKR.
BR
Ter
Old Mar 16, 2019 | 03:16 PM
  #56
u102768's Avatar
Only the XKR.
Old Jun 8, 2019 | 06:53 AM
  #57
SC S/C Jags's Avatar
Very thankful for this post.
Happy to report that changing the e-diff fluid cured the 'shudder from start into a turn' issue for me as well. According to the Torque app, the e-diff fluid is also running at a much lower temp during regular driving.
Dealer changed my e-diff fluid for $400. The highly recommended tranny shop (for all things ZF) down the road couldn't get the filler plug out - weird.
Old Jun 17, 2019 | 09:02 PM
  #58
jeffu's Avatar
I had the read e-diff changed today at my local shop. The car has 28K on it and I was starting to experience the tale-tale "shutter" when I would first start out with the car and on slow sharp turns.
I used the fluid recommended by Queen and Country: RAVENOL J1C1126 Multi-Disc Locking Differential Fluid
The fluid that drained out was discolored but not horrible. My shop charged me $105. Best part was I was able to go down under the car and watch the whole thing. Kind of felt like I was on a school field trip, for adults! That's the first time I was really able to get a good look under the car. She was cleaner than I expected and YES, the shudder I was experiencing is gone.
Old Sep 15, 2019 | 09:39 PM
  #59
trkyam's Avatar
I just put 75w140 in my 2010 XK,
Could someone confirm this is correct?
Any harm in using 75w140 vs 75w90?
Old Sep 16, 2019 | 12:34 AM
  #60
Cee Jay's Avatar
As long as you don't have the E-Diff you'll be fine. The /R E-diffs use clutches so the fluid needs a Friction Modifier, either included in some fluids or as an added little bottle.
