Check Engine Light on when engine off?
Old Nov 14, 2021 | 06:14 PM
SpartanBadger's Avatar
Default Check Engine Light on when engine off?
Hello, today I noticed my 2007 XKRs check engine light came on when in accesory mode.
I havent noticed anything wrong with the car, any advice?
Old Nov 14, 2021 | 08:44 PM
Cee Jay's Avatar
Yeah, that light is on because the engine is broken..... because it isn't running.
Every car built does this, it's to have a visual confirmation that the light isn't burnt out.
Old Nov 14, 2021 | 09:35 PM
Speedmaster's Avatar
@SpartanBadger - This is normal. Now, if it is illuminated when you are completely shut down I'd be worried. I'd be impressed with the eager-beaverness about the light wanting to warn you - but that is unlikely happening.
Old Nov 15, 2021 | 03:00 AM
There is no "accessory" mode as there was in the days of Ignition key positions I and II. One press of the start button puts the ignition ON. The only thing preventing the engine starting is the brake interlock. At this point the bulb check initiates where most of the warnings illuminate for 3 to 5 seconds.
The MIL remains ON until the engine is started or the ignition is switched OFF with another press of the start buton.
If you continue to have the ignition ON without the engine running (for example, playing audio) a warning to start the engine appears in the message centre as the battery begins to drop.
Old Nov 16, 2021 | 04:50 AM
Barry Leftwich's Avatar
if you power on the jag without starting it,everybody's Jag does this.This is normal and it's no problem that you should worry about.But if it stays there when you start the car and about to drive it or it's on everywhere you go when you're driving it,that's when you should worry.
Old Nov 16, 2021 | 08:37 AM
Thanks for the information everybody! I appreciate it!
ek993
Oct 24, 2014 07:34 AM
Noxparadise
May 4, 2012 12:09 PM
XK8Guy
Apr 16, 2008 11:51 AM
