Check engine oil level 2014 xk
Old Jul 10, 2017 | 07:31 PM
BryanL's Avatar
Default Check engine oil level 2014 xk
I'm a little confused on the process for checking the oil level on my 2014 xk.
Instructions state to switch the ignition on (without starting the car), make sure the vehicle is in park, press the trip button on the lighting control stalk repreatedly until the oil can icon is displayed along with the current oil status.
How does one turn the ignition on by pressing the "start" button without turning on the engine.
I assumed there is a two press process to starting the engine however every time I press the "start" button the engine starts!
I've tried quickly pressing the start button and lightly pressing the button but every time I press the "start" button, the engine starts !!!!
What am I doing wrong?
How does one turn on the ignition without starting the engine?
Old Jul 10, 2017 | 07:33 PM
TXFireblade's Avatar
Don't press the brake pedal.
Old Jul 10, 2017 | 07:34 PM
Queen and Country's Avatar
both feet must me outside the vehicle when you press start button.
Old Jul 10, 2017 | 07:36 PM
BryanL's Avatar
Thanks TX....makes sense.
That should probably be included in the owner's manual instructions but I'll take the fall !!!
Old Jul 11, 2017 | 10:23 AM
drbbop's Avatar
Also wait about 10 minutes after you turn the car off also.
Old Jul 22, 2017 | 09:16 AM
PsiFox's Avatar
And parked on level road
Old Jun 23, 2025 | 11:40 AM
LoveMy2010XK's Avatar
Try not pressing the brake while pressing the Start button.
