Chirping sound heater
Old Jun 15, 2022 | 04:42 PM
Howell's Avatar
Default Chirping sound heater
Today, very hot, and when I started, got this odd chirping sound, did not change with fan speed, must be vent control or stuck vent flapper, anyone else have ideas, 2008 XKR Coupe
I have had water from Duck bill issue in the past, but was able to cut it to help drainage.
I suspect it will get worse as that is usually the case!
Old Jun 15, 2022 | 08:34 PM
Cee Jay's Avatar
It may be the aspirator, a little doohickey behind the dash where it looks like it'd be, because nothing else would be there. Those things get dirty and sometimes make noise.
Old Jun 16, 2022 | 03:46 AM
No Quarter's Avatar
Last time I had a mysterious sound from dash, it was a low quality CD. And they keep turning 1-2 minutes after you turn off listening
Old Jun 16, 2022 | 06:42 AM
Howell's Avatar
Default Response to dash noise
This is a great clue, will check out, several other notes on Google search is pointing to device, another jag item that is a mystery gadget, does not look too pricey to replace
Your help is very much appreciated
Howell Owens
Old Jun 16, 2022 | 10:06 AM
Cee Jay's Avatar
A person can usually just clean it gently and have it work properly again. Even a distant shot of canned air gently aimed at the slots could help immensely.
stran0020
Apr 22, 2020 01:36 AM
mrvip
Dec 16, 2018 10:29 AM
bigcat777
Mar 10, 2015 06:41 AM
jagxkrtoofast
Jan 27, 2015 03:26 PM
rtipping
May 18, 2014 09:41 AM
