connecting the CTEK
Not clear if I can connect the negative CTEK lead directly to the battery negative terminal, or need to use certain other chassis ground point.
For your 2016 XJ, connect the negative CTEK terminal to a chassis ground. Do not connect it to the battery. For details, including photos, see: https://www.jaguarforums.com/forum/x...lation-130801/
Originally Posted by Stuart S
(Post 2080132)
There is a ground post in the spare wheel well you can use that. Or you can use any bolt that connects to the frame. If these two suggestions don't work for you, use the search box in the upper right corner of this phrase asking for connecting CTecks to 5.0 Litre X150s.
2 Attachment(s)
Originally Posted by yidal8
(Post 2080149)
Thanks, but I'm asking for the 2013 XKR vert. I just bought.
I chose not to cut a hole in the trim as shown and exited my CTEK extension through the vent grille next to it instead. Graham |
How was anyone supposed to know that you had an XK when your signature shows that your current ride is a 2016 XJ AWD?
https://cimg1.ibsrv.net/gimg/www.jag...937d473b68.jpg See my Post #10 in this thread: https://www.jaguarforums.com/forum/x...ek-mx5-214824/ https://cimg2.ibsrv.net/gimg/www.jag...c3accf998a.jpg |
Originally Posted by GGG
(Post 2080201)
Here's the Jaguar fitting instructions. The factory charger is a re-badged CTEK so the connections and cable routing are valid.
(Post 2080280)
Thanks. Is there a certain way to remove/install manipulate the top divider/tray in the trunk
https://www.jaguarforums.com/forum/x...please-146325/ https://cimg6.ibsrv.net/gimg/www.jag...9453ac585d.jpg |
Fair enough, criticism accepted.
I don't have the car yet, it will probably get loaded on the transporter from the selling dealer in few days (850 miles away). Just getting a little excited and mentally prepared. |
https://cimg9.ibsrv.net/gimg/www.jag...e8198970f9.jpg
Actually looking through that schematic, I still like my install. No wires through the trunk lid seal. My "Plug'N" is below the trunk in the Valance..... Used a marine grade male receptacle. |
What's wrong with a wire through the trunk seal? It's the easiest hook up and has worked for me for many years with no seal deformation or other problems. And there's no sign of a socket when it's unplugged. It's on the left side in this photo. The license plate frame is my wireless solar-powered backup cam, $125 from Costco.
https://cimg7.ibsrv.net/gimg/www.jag...6c2dc44948.jpg |
I liked the cigar marine socket method also as it's easy to plug in after every ride and I don't need to open the boot. Clean and quick.
https://cimg8.ibsrv.net/gimg/www.jag...42b0fd285d.jpg https://cimg9.ibsrv.net/gimg/www.jag...a4b0647790.jpg |
I also keep a digital gauge plugged in just to see the voltage change the Ctek goes through. This is at resting stage 7 reading.
https://cimg8.ibsrv.net/gimg/www.jag...90d1693a95.jpg |
Wow, you use the 'towing package' connector- neat:icon_toast:
(Post 2081078)
Why is it not acceptable to connect the ctek positive to the jump-start stud in the trunk left side and the negative to a ground stud in the spare wheel area?
I think some people are doing this. |
(Post 2082715)
(Post 2082715)
(Post 2082721)
It's OK to connect a CTEK to the remote battery terminals in the trunk that are used for jumpstarting a dead battery, at least for the 4.2L models. I'm not sure about the 5.0L models with the Battery Monitoring module, but I suspect that it's OK, too, because that module isn't in the charging circuit when the remote battery terminals are used. I use a CTEK MUS4.3 on my XJ, but I've been using a BatteryMINDer brand maintainer on my XKR since 2012 hooked up to the remote battery terminals. See this old thread for details: https://www.jaguarforums.com/forum/xk-xkr-x150-33/battery-charge-long-lay-ups-73471/page1/ in particular my posts ## 17, 19, and 21, for photos of how I hooked it up. It's worked flawlessly for the last 7 years with no problems.
(Post 2082932)
Thanks Stuart S: It appears you consider the CTEK alligator clips (in your pics.) clamping force to be strong enough to leave as permanent connections. Am I correct?
https://cimg4.ibsrv.net/gimg/www.jag...6fbf68c1e8.jpg The CTEK alligator clips are much larger and stronger than the BatteryMINDer clips and should work as a permanent connection, but using a locknut is always a better choice. I've had no problems using the alligator clips on the remote battery terminals in my XKR. |
