Convert pump seal
Old May 9, 2020 | 04:23 PM
Pgeorge23's Avatar
Default Convert pump seal
Like an idiot I turned the screw to far and now the hydrolic fluid leaks out of it when the top is manually moved. Is it possible to fix this without having to replace the whole pump?
Old May 14, 2024 | 12:40 PM
wardhill68's Avatar
95 xjs my problem is the rear quarter dont roll down and i hear nothing from the top motor like no power to any of it. Ive cleaned and tested the console switch, checked all relays in the rear to be working, grounded out the hand brake as per a fellow members showed. Still nothing. What next? Thanks for any advice,Jeff
Old May 14, 2024 | 09:25 PM
ralphwg's Avatar
If your inquiry is about an XJS, you are in the wrong forum. Most of the participants here will not be able to help you. Suggest you go to the XJS Forum. You will probably find the info you need there. Good luck!!
texasscot
Nov 26, 2024 12:46 PM
Mattoronto
Mar 23, 2019 03:14 PM
nilanium
Dec 13, 2017 11:17 PM
Justwantsittowork
Sep 14, 2014 07:40 PM
