Convertible roof not working
Old Apr 26, 2020 | 09:34 AM
Buzzer's Avatar
Question Convertible roof not working
I've been scouring the board looking at the many similar posts, but haven't been able to find a solution...
My roof was somewhat stuck in the closed position: the windows would drop and the hood would unlatch but that was as far as it would go. From there it would successfully return to the closed position on command.
I tried dozens of times to do the window resetting, pulling the F8 fuse from the rear seat panel, charged the battery (even though I only tried to move the roof with the engine running)... no joy.
Then I thought I'd try doing a hard reset, by disconnecting the battery's negative terminal for 10 minutes, before manually moving the roof into the open position before doing window resetting (3x each window, multiple times), to no success.
I took a video of the current state of things, and am looking for any next steps to try. The hydraulic fluid level was just under the maximum marker. Battery is fully charged. I can hear some switching going on but never any movement from the hydraulics.... apart from this video, where the pressure does seem to go out of the hydraulics on trying to put the roof in the open position while the tonneau was manually raised:
Any help will be greatly appreciated!
Old Apr 26, 2020 | 09:59 AM
kj07xk's Avatar
Any message show up on the display in your dash?
Make sure your luggage separator is correctly deployed and seated (also make sure the metal part used by the magnetic sensor is on the end of the luggage separator (they sometimes fall off), left hand side if I recall correctly).
Old Apr 26, 2020 | 10:07 AM
WhiteXKR's Avatar
Now that the top is down the roof is in the reset position. I suggest opening the pump valve (CCW) for 30 minutes for the pressure to drop then pushing the tonneau down as far as possible over the folded top.
Then close the pump valve (CW). Now start the engine and see if the top closes normally.
If the top pauses after the tonneau cover opens, continue holding the button for up to a minute and see if it eventually starts moving. If there is a long pause until the top starts moving after the tonneau opens it means the window reset still has not 'taken' and you need to keep trying window resets.
As kj07xl stated, make sure there is no luggage separator warning, and also make sure the boot is fully shut.
Old Apr 26, 2020 | 10:56 AM
Cee Jay's Avatar
A thing I did wrong the first time I tried all this was to not turn the pump valve FAR ENOUGH to both release and engage the pressure. It took me like five minutes of ranting to finally realize my error.
Old Apr 26, 2020 | 11:08 AM
Buzzer's Avatar
Thank you all for those tips!
The one thing I had assumed was alright was the luggage separator since I had no errors on the dash... that'll be my first port of call Will report back....
Old Apr 26, 2020 | 11:24 AM
Buzzer's Avatar
I'm not convinced the luggage separator has the magnetic piece in place, since both sides look the same to me. I had let the missus take it out for a shopping trip, which was the last time I saw the roof working, and wonder if I'd moved the luggage separator for that trip.
WhiteXKR - thanks for your help across all the threads with the roof issues! I will try the half hour pressure release if my luggage separator magnetic piece is missing. Whatcha reckon guys?
left hand side of luggage separator, in the deployed position
right hand side of luggage separator, in the deployed position
left hand side of luggage separator,slightly out of deployed position
right hand side of luggage separator,slightly out of deployed position
Old Apr 26, 2020 | 12:01 PM
Buzzer's Avatar
I found a pic on the forum to show where I should be looking and I think the metal piece is there...
I pulled the F8 fuse again while I let the pressure drain for half an hour
Old Apr 26, 2020 | 01:00 PM
Buzzer's Avatar
After waiting to let the pressure drain, I closed the valve clockwise until the allen key wouldnt move. Started the engine, and did the window reset 3x each side since I had pulled and replaced the F8 fuse.
Still no luck... when I press the top to open button (get it stowed in the back), the engine revs do drop between some hearing some switching sounds, telling me that power is being drawn...
Old Apr 26, 2020 | 01:16 PM
WhiteXKR's Avatar
And when you try to close the top are you continuing to hold the roof button for at least a minute even if the tonneau cover stalls in the open position (like in your video)?
Old Apr 26, 2020 | 01:43 PM
Buzzer's Avatar
Thanks WhiteXKR
To be fair I didnt hold for a minute, just 30 seconds. Still no joy - new video though!
Old Apr 26, 2020 | 01:58 PM
WhiteXKR's Avatar
Try removing F8 one more time for 15 seconds, then try holding the close button again. If it still refuses to move, unfortunately you may actually have a hardware fault in the system.
Old Apr 26, 2020 | 02:58 PM
Buzzer's Avatar
Tried the F8 again but nothing. Any ideas on where to start on the next checks?
Old Apr 26, 2020 | 03:03 PM
Buzzer's Avatar
For what it's worth the whole metal block in the middle of the unit is almost too hot to touch!
Old Apr 26, 2020 | 03:14 PM
WhiteXKR's Avatar
You really should get an SDD scanner on the vehicle and see if any faults are logged in the system to get a clue where to look. My guess is a broken wire or faulty microswitch. It is actually a pretty reliable system, so there are not any common faults I have seen repeatedly.
Old Apr 27, 2020 | 07:52 AM
Buzzer's Avatar
Thanks WhiteXKR -- are there any SDD scanners you would recommend for this? I've been looking at them and not seen a mention of the roof, so wanted to make sure the appropriate module would get scanned.
I also noticed multiple places where wires under the tonneau are zip tied together, and have worn on the wire sheathing in some spots. Is that how it comes from the factory or has mine been worked on and put back together?
Old Apr 27, 2020 | 10:38 AM
Buzzer's Avatar
Which module would the roof operation be in?
Old Apr 27, 2020 | 11:07 AM
DGL's Avatar
DGL
FYI, I seen a convertible roof module available on ebay yesterday. Good luck with figuring this out.
Old Apr 27, 2020 | 11:31 AM
Buzzer's Avatar
Thanks DGL! I plan to keep the group appraised of how this pans out as I've yet to see a problem reported in the forum that wasn't fixed by a simple fix.
As for the module, I meant which diagnostic module is the roof operation contained in a scanning tool?
Old Apr 27, 2020 | 12:21 PM
Cee Jay's Avatar
..... but why would you pump assembly be hot if it wasn't at least TRYING to pump? I'd think you'd need a two-man operation to check. One guy hold the roof switch while the other observed/felt the pump, see/hear/feel what's going on.
Old Apr 27, 2020 | 12:28 PM
Buzzer's Avatar
I agree Cee Jay -- it's the one thing that's giving me hope at the moment! The only snag I see is that I have assumed the mechanism doesn't work while the boot/trunk is open... which would preclude looking at the pump while it's doing its thing.
That is my assumption as I don't have a working one to look at Perhaps I'm missing something you're seeing though!
