Coolant draining and refill, check valve question
Old Jan 18, 2026 | 04:50 PM
BlueXKR-S's Avatar
Default Coolant draining and refill, check valve question
I am getting ready to drain and refill coolant on my 2012 XKRS (x150). I have a manual and all steps are pretty clear except for one. There is a check valve right next to the expansion tank cap and the manual does not really really explain its operation.
1. When normally operating, should it be closed (like picture shows) or open?
2. When draining and refilling, should it be open (line aligned with the tube)?
Thanks,
Old Jan 18, 2026 | 06:49 PM
BlueXKR-S's Avatar
Never mind, I made a mistake, it's not a valve, it's bleeding plug that needs to be removed when filling up and then tightened. Problem solved.
Low-Tech
Mar 4, 2021 01:02 PM
BKSinAZ
Feb 20, 2015 02:55 PM
gregh
Aug 7, 2012 09:15 PM
Gweedo
Aug 18, 2010 07:35 PM
msholmes
Jan 7, 2009 05:57 PM
