Coolant smell ??
Old Jun 15, 2017 | 09:57 AM
myexcursion's Avatar
Default Coolant smell ?? Pics inside
My coolant level was a little low when I checked last week on my 'new to me' XK. I figured I would top it off some. Drove it about 30 miles since then.
Yesterday I took it out for a 20 minute ride on the parkway and when I pulled into the garage back at home it smelled like coolant.
This morning I go to check to see if any leaked, and floor is bone dry. I check under the hood and see this below - Not sure how it would either come out of there or if something worse... Car drives fine and no issues except it smelled a little like burning coolant fluid. Also when checking the reservoir this morning it was slightly below the MIN again. Could I have filled it a little too much ?
Old Jun 15, 2017 | 07:05 PM
So while digging around there I noticed that a hose to the left of where I circled above, looked a bit chafed or as is something had nicked it and looked a little oily around the edges. Decided to take to cat out for a quick spin and started to smell it again within a few minutes. Pulled into the driveway and noticed a trail of orange liquid !
Opened the hood ( bonnet ) and removed the cover. There it was !!! I steady stream like a water gun of hot liquid shooting across and soaking the area in orange fluid. A LOT of fluid coming out - such a small tiny cut shot out roughly a half gallon of fluid !
I traced it out and after some research its the EGR inlet valve hose (Part : Cooling-Water Hose AJ811761 ).
I was able to cut off the part that was gouged when attaching the connector clips ( likely cut when replacing the thermostat or some other component by the previous owner ) since it was about 3/4 inch from the end. I refit the hose for now, even though it has a tighter bend now coming out of the connector, it still holds. I wanted to test it out, put in about a half gallon of coolant to bring the level just below MIN to test. Drove the car around for 5 minutes to get it to warm up. Checked and no leaks were now present
Called the local Jag dealer and they would not be able to get the new hose ( $11 ) until Monday morning. Probably won't be driving the car around this weekend anyhow, so I'll report back next week.
Part #4 from diagram below :
Old Jun 15, 2017 | 07:37 PM
Ranchero50's Avatar
Cool, good job on finding the problem.
Old Jun 15, 2017 | 07:39 PM
Yeah... hopefully it'll help someone else in the future too if they come across something similar
Old Jun 15, 2017 | 08:15 PM
bocatrip's Avatar
07 doesn't help 10 which has coolant smells regularly. Never found my issue after 3 years.
Old Jun 16, 2017 | 12:22 AM
Patrick Wong's Avatar
Maybe the cabin heater core has a very slight leak?
Old May 22, 2018 | 04:02 AM
Ter11's Avatar
Thanks! I am also looking for the reason of coolant smell in my xk. Will need to investigate this hose...
br
ter
