Cruise control 2007 XK
Old Feb 26, 2023 | 04:09 PM
Sampson's Avatar
Default Cruise control 2007 XK
Cruise reading cruise control unavailable. Any suggestions? Serious problem or just a fuse Mabey?
Old Feb 26, 2023 | 04:47 PM
Cee Jay's Avatar
Probably a low voltage on your car battery.
Before doing anything else, make sure it is fully charged and Holding that charge. 12.6 vdc after sitting for awhile.
Old Feb 26, 2023 | 05:00 PM
McJag222's Avatar
Apparently there are two micro-switches (Switch-brake-1 Switch-brake-2 on the electrical schematic) on the brake pedal, one can fail, which causes the issue. I've had it once way back, but can't remember how it cleared.
You could try disconnecting the battery for a minute to do a reset to see if that clears it.
Old Feb 26, 2023 | 05:22 PM
McJag222's Avatar
From the manwell:
Old Mar 2, 2023 | 06:04 PM
MudDog's Avatar
Same car, similar issue.
You really need to use a scan tool to see if its the control module or not.
Right now I get the same error message along with Park Brake Failure AGAIN ARRRGH.
Stephen Kuhn
Sep 22, 2019 09:59 PM
Mar-Vel
Feb 19, 2019 01:26 PM
Davexjrv8
Nov 29, 2011 09:38 AM
vdpnyc
Feb 14, 2011 05:03 PM
