Cruise control malfunction
Old Jul 31, 2019 | 11:01 AM
Mediawiz's Avatar
Default Cruise control malfunction
I purchased a low milage 2012 XKR about a month ago. So far, I'm pretty happy with it.
One problem I have come across is that the cruise control is not working. When the car starts up, I see "Cruise Control Not Available". I scanned the OBD codes, and the only code that comes up is "U0104" (cruise control module communication lost).
Any thoughts on how I might diagnose / repair this?
Anyone know where the Cruise Control Module is located on a 2012 XK(R)?
Old Jul 31, 2019 | 11:36 AM
Ranchero50's Avatar
I would do a hard reboot and see if the communications work once it powers back up. Unhook the battery, hold the cables together for 30 second and hook it back up.
Old Jul 31, 2019 | 12:19 PM
Cee Jay's Avatar
Also make sure the battery is FULLY charged. Fully. Like, on a 20 amp charger for 24 hours.
What type of Cruise is it? By the symptom it would seem ACC, or Adaptive Cruise Control, and that the forward sensor isn't working or is dirty.
OP, do you have the ACC or Normal Cruise?
Are there TWO rotary controls on the right spoke of the steering wheel, or only one?
Old Jul 31, 2019 | 12:21 PM
Mediawiz's Avatar
I tried that. (Had to look around a bit to find the battery.) Didn't help. Still the same warning on the dash when I start the car. ("Cruise not available") Also same OBD code (U0104) even after I cleared all codes.
Any other suggestions?
Old Jul 31, 2019 | 12:24 PM
Mediawiz's Avatar
Yes. Owners manual says "Adaptive Cruise Control". I have only 1 rotary control on the right side of the steering wheel.
Old Jul 31, 2019 | 12:27 PM
Cee Jay's Avatar
You don't have Adaptive if you only have one rotary. You have the "Normal" cruise. No sensors. You'll probably need the module reflashed, or a new module. OR, have you checked all the fuses and such?
Old Jul 31, 2019 | 12:44 PM
Mediawiz's Avatar
Ok. Any idea where the Cruise Control fuse is on a 2012 XK(R)? As I mentioned, I've only had it for a month, and I'm still trying to learn where everything is, and how to work all the accessories.
Old Jul 31, 2019 | 01:49 PM
Sean W's Avatar
Adaptive speed Control sensor is fed from fuse 15 in the engine bay.
Old Jul 31, 2019 | 01:55 PM
Mediawiz's Avatar
There is currently no fuse in slot 15 in the engine bay fuse pannel, and the owners manual for my car (2012 XKR) lists that slot as "unused". I'm happy to try putting a fuse in it, but what amperage fuse should I use?
Old Jul 31, 2019 | 02:30 PM
Stuart S's Avatar
Don't put a fuse in it, as your car does NOT have Adaptive Cruise Control as Cee Jay stated.
ACC-equipped X150 models have 2 rotary controls on the right side of the steering wheel.
Old Jul 31, 2019 | 02:57 PM
Mediawiz's Avatar
Ok. Anyone know where the fuse that powers a "standard" cruise control unit is on a 2012 XK(R) ????
Also, does anyone know where the cruise control module is for that car?
Old Jul 31, 2019 | 03:22 PM
shemp's Avatar
Looking at the Electrical guide, it looks like the regular cruise control (speed control) is done in the ECM. No special module for cruise control. At a glance, it doesn't look like there is one specific fuse but I looked for about 2 minutes. Send me a direct message with you're email address and I'll send you the Electrical Guide
Old Jul 31, 2019 | 03:44 PM
jagtoes's Avatar
I think it's called the speed control module and it is located under the steering wheel. I think the fuse location is in the owners manual.
Old Jul 31, 2019 | 04:06 PM
shemp's Avatar
From what I can see in the service manuals, the speed control module is only present when Adaptive Cruise is available. It's labeled Adaptive Speed Control in the manuals so that makes it unclear to the layman if it is indeed for regular cruise.....
Also, the U0104 code has a 6 different failures associated with it, each marked with a -xx suffix. Probably need a better scan tool to narrow it down.
Old Jul 31, 2019 | 04:42 PM
Ranchero50's Avatar
It would also be a good idea to download the relevant manuals and wiring diagrams.
https://www.jaguarforums.com/forum/x...guides-215509/
Old Jul 31, 2019 | 05:24 PM
Cee Jay's Avatar
Ah.... one thing though....... if there is a fault with your brake pedal switch or stop lamps/wiring, the cruise may not be able to engage. I'm just throwing that out there as an Ole Guy Memory. from previous vehicles.
Old Jul 31, 2019 | 07:45 PM
tberg's Avatar
I have ACC on my 2010 XKR and I've had the No Cruise Control Available warning ever since I added a tune to the ECM about 5 years ago. Since I have never used cruise control of any kind, it never bothered me. I figured that it was related to the resetting of the top speed with the tune, no longer being restricted, but it may have just been coincidence. If you find the solution, I'd be interested in trying on mine as well.
Old Aug 6, 2019 | 01:53 PM
shemp's Avatar
any progress?
Old Aug 6, 2019 | 05:24 PM
Don-T's Avatar
That's from the X100's. The brake light switch has two microswitches in it, one for the brake lights and one to disable the cruise control. Truly a PIA to replace too.
Old Aug 14, 2019 | 06:56 AM
Mediawiz's Avatar
Originally Posted by shemp
any progress?
No. Still same issue.
