CTEK and now problems after installation & use
Old Feb 8, 2015 | 03:55 PM
  #41
Ngarara's Avatar
Originally Posted by doctock993
There was a message, once I started the car, for me to engage the parking brake while braking, prior to driving.
Anything else I need to look for to reset?
That's normal, part of the car's recalibration. The full reset procedure is:
1. Connect the battery cables and tighten to 5 Nm. Ground cable must be connected last.
2. Install the battery cover and close the luggage compartment lid.
3. Start the engine and allow to idle until the engine reaches normal operating temperature.
(n.b.: when you first switch on, the display will ask you to press the brake pedal & apply the electronic handbrake, to recalibrate)
4. Switch the engine off.
5. Restart the engine and allow to idle for approximately two minutes (this will allow the ECM to learn the idle values).
6. Apply and hold the brake pedal, select drive and allow the engine to idle for a further two minutes.
7. Drive the vehicle for approximately five miles/eight kilometers of varied driving to enable the ECM to complete its learning strategy.
8. Reset the audio unit and climate control assembly to original customer settings.
9. Reset the door window motors (wind down & hold until there's a click, wind up & hold for another click).
(n.b. store your current seat positions in M1, then adjust & store any other positions you used to have)
Old Feb 10, 2015 | 09:57 AM
  #42
xk8lattmaster's Avatar
"Personally, With all the newer and sensitive electronics, I would not have any modern day car jump started."
What would be the best alternative?
Old Feb 10, 2015 | 02:36 PM
  #43
Ngarara's Avatar
Use a booster battery, not jump leads to another car.
Dz1rfj
Jul 17, 2018 10:29 AM
afterburner1
Dec 16, 2015 12:12 AM
pegasus3710
Sep 5, 2015 09:40 AM
AL NZ
Sep 4, 2015 08:39 PM
mcdutch
Sep 4, 2015 03:38 AM
