Dead battery
Old May 29, 2020 | 08:18 PM
Canadacat's Avatar
Default Dead battery
Why I am not sure. Didn't have it on the ctek but was fine a few days earlier. It was dead flat
. It wouldn't charge from a charger no matter what I tried. Ended up boosting it from wife's car and it charged itself from the alternator?
kinda strange, I will see if it starts in morning again. But why wouldn't it charge from a charger but charge from the alternator.
Old May 29, 2020 | 08:56 PM
Stuart S's Avatar
A CTEC is a battery maintainer, not a charger.
https://www.oreillyauto.com/battery-...er-differences
Old May 29, 2020 | 09:00 PM
Canadacat's Avatar
Yes I realize that, I tried with a battery charger, actually I tried two.
Old May 30, 2020 | 01:00 AM
JagV8's Avatar
You can need quite a big current (which an alternator readily supplies) to get a really flat battery going - and even then they don't always.
Were your chargers actually supplying 10-20A? I'm suspecting not.
Old May 30, 2020 | 06:39 AM
Canadacat's Avatar
Yup had them on 10 amp , nothing. One even had a 70 amp setting which I could get the car so dash lights would come on but on that setting had to turn off after 30 second because charger cables started to smoke and melt. Cables were only #12 to small for 70 amps for any amount of time
Old May 30, 2020 | 07:26 AM
JagV8's Avatar
You'd need 12-24 hours at 10A. Did you try that?
Old May 30, 2020 | 08:08 AM
1 of 19's Avatar
In my experiences with Jags is once a battery goes completely flat it is never the same. After you get this one fully recharged if anything weird and strange takes place this summer/fall suspect the battery first.
mij86
Jan 13, 2018 11:04 AM
FlamurAdili
Nov 15, 2017 02:49 PM
Dymaxxion
Oct 9, 2017 01:25 AM
robbing
Apr 12, 2016 10:51 AM
jagtoes
Jan 29, 2016 03:44 PM
