Dead touch screen and TPMS fault
Old Aug 14, 2019 | 02:12 PM
pk4144's Avatar
As expected, the fuse is fine.
Was going back to disconnect the cables to do a hard reset-- realized that, even with the car shut off, the DVD (for the nav system, I assume, I'd never seen in before) was spinning up then shutting off repeatedly as if it were trying to read a disc. Could THAT be the culprit, in therms of battery drain???
Old Aug 14, 2019 | 07:05 PM
pk4144's Avatar
Did the touch-the-cables-together hard reset. My screen is back - that's good! - but so are the "Christmas Tree" rotating TPMS warnings, which I hadn't seen in a few days. STILL haven't been back to get the battery checked.
Old Aug 14, 2019 | 08:24 PM
tberg's Avatar
Try inflating your tires to 40psi and see if the light disappear. I used to have it all of the time, not once since I overinflated the tires.
Old Aug 14, 2019 | 09:55 PM
pk4144's Avatar
Yeah, I've done that in the past, may do it again. I'm being stubborn. I hate doing something wrong (overinflating) to make another thing right (the warnings going off). I'm sure there's a Life Metaphor in there somewhere.
Old Aug 15, 2019 | 12:57 AM
Queen and Country's Avatar
Or go to Costco, give them $20, they will suck all the air out of the tires and put fresh back in. Worked for me.
Old Aug 15, 2019 | 04:04 AM
jagtoes's Avatar
Try having the batteries checked in each wheel sensor. Usually last for about 7 years so if you have the original sensors they may be at the end. Tire shop can check them with a wireless tester.
Old Aug 16, 2019 | 11:17 PM
pk4144's Avatar
Good idea. Get the nitrogen and have them go over like 2lbs per wheel. I just hate costco.....
Old Aug 16, 2019 | 11:35 PM
  #28
pk4144's Avatar
Old Aug 17, 2019 | 10:29 AM
Cee Jay's Avatar
I used to use 100% (or so) nitrogen, now I use 76% nitrogen. It's easier.
Old Aug 17, 2019 | 12:38 PM
  #30
tberg's Avatar
pk4144,
Over inflate to 40lbs, see if the warning disappears, then slowly deflate to normal pressure. It has worked for me in the past.
chazaroo
Jan 17, 2019 10:17 AM
Jagstefano
Dec 26, 2018 04:25 AM
dawnvickieaustin
Jun 18, 2018 06:35 PM
Cajuncat
25
Oct 17, 2011 10:21 AM
mojorising
Oct 26, 2010 09:52 AM
