Directions for reading and flashing PCM ( aka ECU ECM ) maps in SDD
Running SDD 157 stable, looking for directions on how to download my PCM map so I can send it for a tune,
and also how to upload or flash the new PCM once received.
I understand some PCMs have 8 maps built into them, is there a way of selection such maps via SDD or ODB2 port?
Thanks again.
Thanks again.
Update, there are .BIN files in the SDD folder on your computer which contain the PCM map, i'm not sure which BIN file
is for the PCM, once I figure that out, I can send it out for a tune I believe.
I will update you all as I learn as well.
As I said a few times before , can send my equipment to tune your ECU and if you need to put it back to stock later you can always use your Sdd . Easy breezy 😉...
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
