Disabling TPMS module in JLR SDD
Old Jul 3, 2017 | 11:21 PM
trkyam's Avatar
Default Disabling TPMS module in JLR SDD
Anyone know how to remove the TPMS module in SDD?
Whenever I use the automatic headlight function, when
I lock my car and come back, TPMS always goes off on usually
all the tires and it circles around.
When I don't use automatic headlight function, no TPMS problems.
looking to disable the TPMS module through SDD,
TPMS is such an annoying feature..
Old Jul 4, 2017 | 12:49 PM
Sean W's Avatar
Download the CCF file, sort it in alpha order, select TPMS and disable it or select not equipped. You should know that it's required under Federal Law. Just an FYI.
Old Jul 10, 2017 | 03:31 PM
flyc2c's Avatar
Have you done this? I have someone who *might* have access to an genuine Jag computer.
I'd love to disable the stupid occasional TPMS warnings. It takes away my clock!
Old Jul 10, 2017 | 08:35 PM
Cambo's Avatar
Disabling the TPMS in the CCF requires engineering mode, it's not available to be changed in a normal SDD, the dealers are blocked from doing this as well.
Old Jul 10, 2017 | 10:42 PM
ralphwg's Avatar
You can disable the warning by pushing the little red triangle on the infotainment screen. It is located on the bottom of the screen on the right hand side about 1/3 of the way in from the right edge of the screen. You will get your clock back.
Old Jul 10, 2017 | 11:36 PM
Cee Jay's Avatar
Yes, but the idiot lights on the dash will remain on.
Old Jul 11, 2017 | 07:12 PM
ralphwg's Avatar
I never promised no idiot lights.
Old Jun 29, 2019 | 08:51 AM
flyc2c's Avatar
Is there a hack for getting in to engineering mode?
Old Jun 30, 2019 | 07:40 PM
Ranchero50's Avatar
Thumbs up
A foam ear plug takes care of that...
