Disconnecting the Electronic Suspension
Old Jan 6, 2017 | 07:43 PM
ajzride's Avatar
Default Disconnecting the Electronic Suspension
Does anyone have any info or ever tried to disconnect the auto dampening ride control?
it turns out that I ordered the standard shocks instead of the electronic ones, I didn't even realize I had the ride control until I pulled the shock and there was a pigtail on it.
I could order the electronic shocks, they actually have a much shorter lead time. But since I'm mainly taking the car to the track, I'm not sure that I really need it and they are 3x expensive.
Given how picky the sensors on this car are, I imagine at the very least I will lose cruise control and probably traction control if I leave the sensors disconnected.
Since Jag seems to offer the XK without the ride control, there must be a way to recode the ECM to tell it that the car doesn't have that option right?
Old Jan 6, 2017 | 08:17 PM
ajzride's Avatar
So I found this thread which seems to indicate that just disconnecting the ADCM module will solve the problem:
https://www.jaguarforums.com/forum/s...ension-137056/
And I located the ACDM module here
http://www.jagrepair.com/images/Elec...KR%2010_23.pdf
I'll post feedback when I'm done.
Old Jan 8, 2017 | 06:14 PM
jahummer's Avatar
All you have to do is pull the fuse 14 from the driver's footwell fuse box. The suspension will be set to the firmest mode.
https://www.jaguarforums.com/forum/x...ndling-114341/
Old Jan 8, 2017 | 07:23 PM
ajzride's Avatar
Thanks!!
