Display screen will not stay on - 2012 XK
Upon startup is fine, but after approx 5 minutes the screen will go blank. I have disabled the screen dimmer function but makes no difference. It still seems to be working as it will beep when I touch it.
Almost every electrical problem will be caused by a Low Battery. There are many threads in here about that subject.
How old is the battery? How often do you drive it a long distance? Do you have a GOOD battery MAINTAINER? NOT a trickle charger as that will kill a battery.
Battery voltage should be at or above 12.6 volts after resting for awhile.
Maybe have a battery load test. Also, CHARGE the battery at least once, with a good 10 Amp charger or higher, preferably overnight or 24 hours.
Possible but not common is the TSD is bad. Not a horrible job to change and also not too much $$$
Keep it on a maintainer. Even daily drivers can have problems.
coleman645
Sep 2, 2018 10:29 AM
