DIY supercharger oil change
Old Oct 11, 2019 | 02:55 PM
  #41
George05's Avatar
Originally Posted by d a
Thanks for sharing. I'm new to the XK world (just got my 2010 XKR) but I anticipate this type of work. Does the service manual cover this job and list the intervals for changing the fluid? How much fluid does the SC require? I've changed my 95 Tbird SC fluid and also R&R the supercharger for other engine work. How difficult is the SC removal from this engine? thanks again and happy motoring.
Don
Sorry Don it was late last nite . intervals are every 50k miles . I cant remember off hand how much old oil i pulled out and put in. but read the start of this thread it should be on there
Old Oct 18, 2019 | 09:50 PM
  #42
TexasTraveler's Avatar
I changed my SC oil using George05 method... It was a PITA but 3.5 hrs later it was done.... The oil was a little yellow/brown compared to the new oil which was close to clear. But here is were it got a little odd for me, I only had about 150ml in the SC, but was able to put back in close to 210ml... Where did my SC oil go? Or was the factory fill low?
Old Oct 18, 2019 | 10:54 PM
  #43
Queen and Country's Avatar
TT what allen wrench did you use?
Old Oct 18, 2019 | 11:02 PM
  #44
I used a T handle 3/16” cut down to where I had about 3/8” of the allen left to use....
Old Oct 18, 2019 | 11:12 PM
  #45
Baked on to the metal in the SC.
10 years of baking at 204 degrees after you turn the engine off.
Old Oct 19, 2019 | 12:30 AM
  #46
George05's Avatar
Well done . Yes a right PITA of a job to do with that wiring harness in the way , but bet you feel better knowing it is all done now . Mine was the same took out less than i put in Q&C is right again . Some of it must get evaporated or burnt up over the years . my car felt smoother with the new oil in much like the transmission oil
Old Oct 19, 2019 | 12:01 PM
  #47
d a's Avatar
d a
Wow, 3.5 hours just to change the oil? Has anyone timed how long it takes to remove the supercharger entirely? What part of Texas do you claim? I'm in the San Antonio area.
Old Oct 19, 2019 | 12:09 PM
  #48
George05's Avatar
3.5 hrs is Quick took me 2 days
Old Oct 19, 2019 | 12:12 PM
  #49
Cause you lead the way Pilgrim
Old Oct 19, 2019 | 12:15 PM
  #50
Cee Jay's Avatar
I don't mean to be "that guy", but couldn't a person merely drill a hole in the FRONT of the SC and tap it for a plug? It'd take about twenty minutes, start to finish.
Old Oct 19, 2019 | 12:22 PM
  #51
George05's Avatar
You guys inspired me . Great info on here
Old Oct 19, 2019 | 12:24 PM
  #52
George05's Avatar
True. Why did Jaguar not leave it were it was on the 4.2l cars when they made the 5l ones
Old Oct 19, 2019 | 12:33 PM
  #53
well it’s one of those things that when your doing it the first time and only one other guy has done it before you that you know of, you just take it slow so you don’t mess something up... Knowing what I’m doing now I could probably cut that time down considerably... I’m in Rockwall/Heath TX a community that is 25 minutes east of Dallas, by Lake Ray Hubbard...
Old Oct 19, 2019 | 12:35 PM
  #54
Cee Jay's Avatar
They did leave it there, but the SC is backwards on the 4.2, that's where the intake is.
Right? Least that's what I think.
Old Oct 19, 2019 | 12:47 PM
  #55
George05's Avatar
Duno
Old Oct 19, 2019 | 12:54 PM
  #56
Lead the way... I know that this is something that everyone should probably be doing because my oil was almost half gone...
Old Oct 19, 2019 | 12:58 PM
  #57
Cee Jay's Avatar
I will take a good look at it next time I have the bonnet opened up. I'll do some preliminary figuring now, finding low spots and such.
Hey, ya never know, it may be super easy. Or super not-possible.
Old Oct 19, 2019 | 01:05 PM
  #58
George05's Avatar
Main problem is that wiring harness in the way . the vacum tube just pulls out
Old Oct 19, 2019 | 01:08 PM
  #59
George05's Avatar
Yeah mine to same as you i put more in than i took out. just shows you we should all check if possible
Old Oct 21, 2019 | 02:39 PM
  #60
rsqrd930's Avatar
+1 on that. What would be the harm if you are careful?
