Does 2010 xkr have LSD?
Old Feb 17, 2026 | 12:06 PM
Street cat's Avatar
Default Does 2010 xkr have LSD?
Thought the 2010 xkrs came with LSDs but recently got stuck in snow and only one wheel spun. Seems like an open dif
Old Feb 17, 2026 | 04:08 PM
kj07xk's Avatar
Electronic diff, not a true LSD. Probably other factors than just rear wheel rotational speeds involved, like maybe vehicle speed.
Old Feb 18, 2026 | 12:38 PM
Cee Jay's Avatar
Which of the two active duplicate threads do you want to keep? An Admin or Moderator can merge them.
Old Feb 21, 2026 | 01:30 PM
Bill400's Avatar
Electronically controlled limited slip differential. The clutch plates are located in the differential.
So, a motor engages the clutches to couple the rear axles rather than using an internal mechanical device or selectively applying brakes.
The function (clutch plates, motor) on your 15+ year old XKRS may require attention.
Did someone turn it off in CCF rather that repair it to extinguish trouble light, diagnostic codes?
CDNXKR
Canada
Oct 4, 2024 08:13 AM
sts-v
Mar 29, 2024 09:41 AM
Stuart S
Aug 28, 2023 07:18 AM
Speedagent
Jul 31, 2021 06:57 PM
GhostriderXKR08
Mar 23, 2009 11:20 AM
