Does 2010 xkr have LSD?
The electronic LSD requires a subtle change in its usage from the classic mechanical LSD.
As per your owners manual, turning off traction control is necessary. Having an appropriate engine rpm is necessary, and some traction is necessary. If you are using summer rated tires in snow, forget it. All seasons, maybe.
wonder if the e dif LSD only activates at speed.
