Double locking-what I learned today
Old Apr 7, 2026 | 05:50 AM
davidmaria1's Avatar
Default Double locking-what I learned today
Recently, to better monitor my coolant temp, I bought an OBD2 multi monitor thingy with a small screen that plugs into the obd port.
It works well and is not obtrusive.
Last night plugged in the maintainer (noco genius 5) and locked the car. . This morning I noticed the monitor was still lit, I unlocked the car then "double locked" it and the monitor was off when I
checked it about 30 minutes later.
So, I'm guessing the car doesn't fully "shut down" with a single lock press?
Old Apr 7, 2026 | 08:28 AM
wymjym's Avatar
Correct!
wj
Old Apr 7, 2026 | 12:36 PM
Stuart S's Avatar
Not exactly. Double locking will shut off Convenience Mode, instead of it taking about 20 minutes to time out by itself. That can help your battery to last longer.
US members who "double lock" their X150 will get a "beep beep" from the sounder. That double beep is an error message that means your car is not double locked. That's because double locking is not available on US market vehicles.
Double locking is not available on USA market vehicles because the National Highway Traffic Safety Administration (NHTSA) deemed it to be unsafe. Double locking is popular in Europe because it makes cars more difficult to steal. However, because the doors cannot be opened from the inside when double-locked, a small child, pet, or other passenger can be trapped inside and die from extreme heat.
When you double-lock your car, the beep-beep is an error message to tell you that your car is not double-locked. Visual confirmation that your car is locked is that your side mirrors automatically folded in, unless you disabled that feature or your car is not equipped with that feature.
For more information:
See: NHTSA January 2009 Double Locking
Stuart
Old Apr 7, 2026 | 12:59 PM
That's how I originally understood it. I have never heard the sounder. That may only mean that it's faulty and the locking/beeping process is working. That being said, what caused the device to remain lit overnight with the car locked? This morning, after unlocking and then locking with 2 quick clicks, the device shut down in approx 30 minutes. It's not a big deal, there's a physical power switch on the device. There seems to be some differences in our cars.
Also, does the dash led blinking correlate to the number of remote clicks?
edit: I understand the function of the led/alarm
Old Apr 7, 2026 | 01:25 PM
wymjym's Avatar
Not meant to offend but, when I' double click' my remote I do not get a beep beep, just a click click sound coming from the doors. There is a quicker drop in the ma draw but, I have found that when that draw is weighed against not 'locking' (it stays at home in the garage most times) my car's battery holds at 12.4 (yes I know, not 12.6) for several days before it starts dropping. If double clicked it drops daily.
I've given up trying to determine the culprit for the phantom draw my 2008 xk exhibits.
wj
Old Apr 7, 2026 | 02:46 PM
Circumnavigator's Avatar
wj
I don't get any noise other than the clicking of locks when I double mine either (08 XKR). Many times I'll have to turn around to see the turn signals flash to make sure it is locked. (Kids don't always shut the door properly as it is heavy)
Only annoying thing with the proximity unlocking. I can't go pull the handle to see if it is locked, unless I'm gonna toss my fob into the bushes or something.
Old Apr 7, 2026 | 03:30 PM
I would have expected a car to draw less if it were "asleep "
Old Apr 7, 2026 | 03:41 PM
wymjym's Avatar
when asleep, after double clicking, the alarm is set
wj
Old Apr 7, 2026 | 03:46 PM
wj
That's the difference. I noticed the alarm led flashing during the cycle that shut off the obd port.
Old Apr 7, 2026 | 10:12 PM
Bob Laker's Avatar
Récemment, pour mieux surveiller la température de mon liquide de refroidissement, j'ai acheté un multi-écran OBD2 qui se branche sur le port OBD.
Il fonctionne bien et n'est pas gênant.
Hier soir, j'ai branché le chargeur (Noco Genius 5) et verrouillé la voiture. Ce matin, j'ai remarqué que l'écran était toujours allumé. J'ai déverrouillé la voiture, puis je l'ai verrouillée une seconde fois, et l'écran était éteint lorsque j'ai
vérifié environ 30 minutes plus tard.
Je suppose donc que la voiture ne s'arrête pas complètement avec une simple pression sur le verrou ?
Sur une prise OBD-II standard, la broche 16 reçoit normalement un +12 V permanent directement relié à la batterie, même contact coupé. Les broches 4 et 5 sont les masses. Cela permet d'alimenter un lecteur OBD ou certains accessoires sans avoir besoin de mettre le contact.
Cependant, sur certains véhicules, ce +12 V peut être protégé par un fusible dédié ou coupé après un certain délai pour éviter de décharger la batterie.
Old Apr 8, 2026 | 08:07 AM
Stuart S's Avatar
If you don't hear a "beep beep" from your sounder when you double-lock your XK/XKR, it probably needs to be replaced. Your side mirrors will confirm that it's locked by automatically folding inward if your car has that option and it has been activated in the Vehicle Settings.
Stuart
Old Apr 8, 2026 | 09:27 AM
wymjym's Avatar
Where is it located? What does it look like? I searched under the cowl covers areas and never saw one.
wj
Old Apr 8, 2026 | 10:51 AM
Stuart S's Avatar
Here's how to locate the Sounder. The link is to another Jaguar forum in the UK. Save $$$ and buy the same part from Ford. Or to save even more, replace the internal battery in your defective Sounder
https://www.jaguarforum.com/threads/...l-arch.133750/
How did I find this? Simply do a Google search. Start by entering Jaguar X150 Forums followed by what you want to know. I Googled "Jaguar X150 Forums how to locate and replace the Sounder". Do it and read the AI response.
Old Apr 8, 2026 | 10:59 AM
wymjym's Avatar
I do think, but I'll keep my initial thought about your response to myself.
One more question, do you enjoy demeaning individuals?
Have a good life!
wj
Old Apr 8, 2026 | 05:25 PM
HealeyJag's Avatar
I disconnected my sounder...
Annoying to me...and worthless
Old Apr 8, 2026 | 08:25 PM
Stuart S's Avatar
Have a good life!
wj
Your reply shows that you didn't keep your initial thought to yourself.
Old Apr 8, 2026 | 09:44 PM
McJag222's Avatar
Have a good life!
wj
You forgot to like his post.
Old Apr 8, 2026 | 10:16 PM
Cee Jay's Avatar
So how about them Yankees? Anyone think they have a chance at the pennant this year?
Old Apr 9, 2026 | 10:18 AM
guy's Avatar
guy
@wymjym , I didn't see anyone answer your question... Of course I was not reading closely.
Old Apr 9, 2026 | 05:18 PM
HealeyJag's Avatar
Originally Posted by cee jay
so how about them yankees? Anyone think they have a chance at the pennant this year?
nope...
Go tribe!!!!
