Driver's seat moves when braking hard
Old Nov 25, 2017 | 11:28 AM
Macc's Avatar
Default Driver's seat moves when braking hard
This is at least a bit irritating/cheap. With hard acceleration or braking, the seat moves a bit. Something is loose, but what? I cannot hear any strange sounds.
Old Nov 25, 2017 | 11:31 AM
Cee Jay's Avatar
Did you check the mounting bolts?
Moves how? The back moves independent of the bottom? The bottom moves independent of the back? Both move? The back twists? The entire thing twists?????
NEED INFO!!!!!!!!!!!!!!!
Old Nov 25, 2017 | 01:57 PM
Macc's Avatar
Whew Ok. The bottom slides a bit forward when I brake, the rest of the seat follows of course. Something wrong in the bottom. And it really _slides_, perhaps half an inch or less. Still feels unsecure.
Old Nov 25, 2017 | 02:31 PM
Ranchero50's Avatar
Yeah, mine does too. Kind of a pop / click but only on breaking when my weight against the back goes neutral. It started when I lifted a front a little to fit me better. Everything's still tight otherwise.
Old Nov 25, 2017 | 04:38 PM
Cee Jay's Avatar
Sounds like the fore-aft linkage/gears/whatever is either worn or out of alignment. Seat needs to come out then shoved around while looking underneath it for any give.
Old Nov 25, 2017 | 07:49 PM
mosesbotbol's Avatar
My XK did that everything looked to be in order. Had my indy look at it a few times. Sometimes my Aston does it too. Annoying, but good luck ever figuring it out. Thought I was crazy... Guess not.
