Engine front end maintenance
Old Dec 1, 2022 | 07:14 PM
DGL's Avatar
DGL
Default Engine front end maintenance
I have less than than 20k miles on my XKR. I'm sure at sometime my water pump, timing chain tensioners or another component on the front of the engine is going to fail. When I need to access the front of the engine to replace one of these known parts which fail I'll replace the belts, tensioners, water pump etc while everything is apart and open for access. When servicing these components is it recommended to remove the hood and bumper for easy access. It would be a project I take on over the winter months.
Old Dec 1, 2022 | 09:01 PM
steve_k_xk's Avatar
When I did chains I had radiator, radiator shroud, aircon condenser, power steering cooler, cross brace & top lock all out to provide full access being supercharged you'll also have heat exchanger radiator .
Front bar stayed on for me but yes hood off
Old Dec 1, 2022 | 11:10 PM
jahummer's Avatar
With the hood out of the way it makes a massive difference.
Lord_Eduard
Dec 18, 2020 02:25 PM
iramphal
Sep 5, 2019 06:43 AM
jkann1
Feb 23, 2017 10:41 AM
dickc
Apr 16, 2015 06:40 PM
daddyo007
Mar 6, 2011 09:58 AM
