Engine temp high warning
Old Oct 24, 2014 | 03:00 PM
bigdhenderson's Avatar
Default Engine temp high warning
Engine temp high warning. 2nd occurrence. ELM327 is indicating less than 190 degrees while driving. The first time this happened I shut car off immediately... Let cool for 20 mins, drove home. No problem since. Just happened again right now, I'm waiting to pick my son up from school. Im so scared of a possible water pump failure because of everything I've read on this forum about the XKRs, but indicated temp is less than 190...any ideas?
Old Oct 24, 2014 | 03:04 PM
Lothar52's Avatar
Yeah id be concerned about water pump as well. I would drive it directly to the dealership and if you think it is too far away get a wrecker and call wife to pick you up!!!
Old Oct 24, 2014 | 05:32 PM
bocatrip's Avatar
I wouldn't take a chance driving it to the dealer. Better safe than sorry. Flat bed it there. You only need to cook the engine once!
Old Oct 24, 2014 | 06:44 PM
I guess what I'm more getting at is, is this an electrical gremlin? How can the engine temp high be dislplayed and only be reading 190° or less. Possibility of a faulty sensor? It has plenty of coolant. Cooling fans are on. There must be two separate sensors. Anyone have a diagram?
Old Oct 25, 2014 | 12:06 AM
Also, after the first time it did it over a week ago, after I let it cool down for 20 mins or so and checked the coolant level and found it was good, I beat the snot out of it on the way home and didn't have another reoccurrence until tonight. Its not a daily driver for me but ive put on 300+ miles in between occurrences. And I will be doing all of my own work on it, other than the stuff I'm not equipped to do like programing stuff. I have my own shop with car lift, and I do have a very good mechanical aptitude along with an associates degree from Wyotech in automotive technology with chassis fabrication and high performance engines.
Old Oct 25, 2014 | 01:35 AM
CleverName's Avatar
Tell us what motor you have or year of car.
I notce that both your post and signiture section are void of information that would help us help you.
If it is the 5.0l, be afraid...Be very afraid..... Tow to your nearest dealership and have the system looked at. If the 4.2, suspect the thermostat and housing assembly.
These are known areas of overheat on both platforms.
The 5.0 is gaining a slight reputation for frying motors quickly on a failed pump, so minimize your risk ASAP.
BOL
Old Oct 25, 2014 | 12:35 PM
its a 2010 XKR. 5.0L..
Evidently my sig doesnt show up when posting from my phone. Posting from laptop now I see it shows up
Old Oct 25, 2014 | 06:30 PM
axr6's Avatar
Very interesting scenario. I thought that the ELM 327 would get its OBD II readings from the same sensor source as the one triggers the temp alarm. Obviously NOT the case.
I would trust the ELM 327 read as accurate and suspect what ever sensor is acting up that triggers the warning.. Either way a trip to the dealer to replace the sensor would be in order, unless you venture to do it yourself. The fact that you are NOT loosing coolant also backs up the bad sensor theory.
Old Oct 28, 2014 | 07:20 PM
pending code P1116 Engine Coolant sensor out of range/ECT Sensor Out Of Self Test Range today
Old Oct 29, 2014 | 03:42 AM
JagV8's Avatar
Check wiring etc / change sensor.
Old May 17, 2015 | 09:18 AM
had this same issue a couple times so far already this year. Anybody know this part number?
Old May 17, 2015 | 11:23 AM
jagtoes's Avatar
I use a little common sense in situations like this. The 1st thing I would do is stop the car , turn off the engine and pop the hood. Look for smoke and if none then look under the front of the car and also smell the engine . If no antifreeze smell or any coming from under the car or blowing out of the coolant tank then you don't have a problem. Oh also check to see if the rad. fan is running or cycling. For those with an ELM and a torque pro type of app and the temp is in line (190*-200*) then you should be good to go. I would check and log the code and erase it and see what conditions come up in the future.
Old May 17, 2015 | 05:33 PM
bocatrip's Avatar
Am I correct to assume that both the XK and XKR 5.0 from 2010 forward both have overheating issues? I've questioned my shop foreman and I believe both engines are vulnerable to this issue. Mileage might not necessarily matter as I've heard of Jags with as little at 5,000 miles cooking. Not happy about this which limits me to how far I can drive from home.. Ridiculous for such an expensive car! I do have a warranty but of course those notorious "loopholes"!
Old May 17, 2015 | 06:12 PM
tberg's Avatar
The issue with "cooked" 5.0L engines is related to oil starvation, not necessarily coolant system failure. Without easy to read gauges or a dipstick, most drivers simply don't check until it's too late. This is what happened to the previous owner of my car and I got a new engine as part of the deal I made.
Old May 17, 2015 | 09:09 PM
guys, if anyone has the part number for the coolant temp sensor that would be really great. The codes its been throwing is for self test out of limits. I just need to replace the sensor.
Old May 17, 2015 | 09:31 PM
Stuart S's Avatar
Default Failed The Smell Test
Jagtoes,
I agree, but would add one more common sense "Old School" thing to do if you get an overheating warning. Turn the heater on FULL BLAST MAX TEMPERATURE AND FAN SPEED and direct the airflow to the upper vents. Make sure there is very hot air coming out of those vents. If not, then odds are that the water pump is not pumping even if the radiator/overflow tank appears to be full and you don't see any leaks or smell any coolant. If hot air is coming out, you're lowering the engine temperature by using the heater core as an auxiliary radiator and, provided you still have sufficient coolant, you might be able to continue to drive a bit farther without damaging the engine (with the windows open, of course) - but I don't recommend doing so because you still risk frying the engine, particularly in the absence of a reliable temperature gauge.
MY EXPERIENCE: I didn't have any overheating warning or any apparent leaking or coolant loss but when I parked and noticed the faint, tell-tale smell of coolant aroma from my 2013 XJ 5.0 SC I immediately went to my dealer to get the water pump inspected. Sure enough, the technician saw a trail of dried coolant that had been slowly leaking from the water pump and replaced it under my CPO warranty. This was about 5 months ago, and so far, so good.
Stuart
Old May 17, 2015 | 10:18 PM
Stuart S's Avatar
Bocatrip,
I believe the defective water pump issue applies to all 5.0L Jaguar/Land Rover engines in vehicles built prior to 9/1/2012, and possibly later. All 5.0L V-8 models are affected, including XF/XFR, XK/XKR, XJ/XJR, F-Type, and Land Rover models. As I explained above, the water pump in my 2013 XJ SC was replaced under warranty, so the defective pumps were installed at least through my 9/1/2012 build date. I don't know the cut-off date after which cars were manufactured with the newer-design water pump.
There is a TSB on the water pump in the 2011 5.0L XJ SC - #JTB002782 as reported by ALLDATAdiy Automotive Recalls and Technical Service Bulletins for 2011 Jaguar XJ (X351) V8-5.0L SC. Provided by ALLDATA but you have to pay for it through a subscription, which I don't have. There may be other water pump TSBs. Hopefully, a tech on this forum will let us know and post a copy of that water pump TSB.
Stuart
Old May 17, 2015 | 10:43 PM
NBCat's Avatar
Here is a thread on the water pump issue with some good information in several posts:
https://www.jaguarforums.com/forum/x...cement-103526/
Old May 18, 2015 | 07:42 AM
jagtoes's Avatar
I tend to pay attention to water pumps as with my old Ferrari they would only last to 20-30K miles. And the rebuild was $300+ and a bear to remove. A new one was in the $500-$1000 range depending on OEM or aftermarket improved versions. That being said I am not happy if I were to see a weep trail coming out of the bearing vent hole. I have also seen some info that with cars that are stored for months it is detrimental to seals and especially WP bearings/seals. Usually the smell is the 1st indication of having it replaced so I'll keep my nose ready and do an occasional check with my Torque app.
Old May 18, 2015 | 09:53 PM
Stuart S's Avatar
NBCat's link is to the XF Forum. Here's a link to another thread on the XJ Forum (that I forgot that I started ): https://www.jaguarforums.com/forum/x...placed-132537/
