Erratic Rpm
Old Mar 14, 2012 | 08:27 AM
Tahoe Dave's Avatar
Default Erratic Rpm
Yesterday I was approaching the freeway and had to fully accelerate in order to avoid an oncoming vehicle. The XK downshifted into “passing gear” and after I noticed that the engine RPM was somewhat erratic. Specifically, the RPM was indexing, for a brief period, before it settled down.
Anyone out there had this experience?
Old Mar 14, 2012 | 06:53 PM
rscultho's Avatar
Dave - what is the elevation where you have yo' crib?
Old Mar 14, 2012 | 07:39 PM
user 2029223's Avatar
Banned
3 thoughts in no particular order. Rev. limiter, MAF or Oxygen sensors. If as you state, you had 1 down shift while merging, rev. limiter not likely but I would definitely check out the other two. If they all check out you may want to look at the fuel filter.
You did not state the milage on your car.
Old Mar 14, 2012 | 11:35 PM
Tahoe Dave's Avatar
Thanks for the replies, the elevation 700 feet above sea level and the mileage on clock is 32500.
I will drive the car this weekend and try to duplicate the symptom.
Old Mar 15, 2012 | 04:43 AM
rscultho's Avatar
So your elevation should not be an issue. At higher elevations the oxygen and pressure levels are different and requires adjustments for ignition - sometimes these corrections are sluggish - that was my line of thinking. I thought since you were in Nevada you may be at a high elevation.
Old Mar 16, 2012 | 12:44 PM
TomServo's Avatar
One of the many symptoms I experienced on my 08 XK attributed to a failing battery was erratic RPM's from time to time. A new battery cure all of my electrical gremlins.
You can get the battery checked from free.
Good luck
Tom
inactualis
Oct 2, 2015 11:13 AM
baskervillema
Oct 1, 2015 01:59 AM
dansxj6
Sep 28, 2015 08:02 AM
NTL1991
XJ40 ( XJ81 )
Sep 20, 2015 06:22 PM
