Error codes
Old Mar 31, 2021 | 12:50 PM
Canadacat's Avatar
So changing the coupler solved the 430 code, i have the same code but my car drives fine. I would have thought if the coupler was split or disintegrated it would throw a vacuum code and idle high. MIght try the old butane torch trick around it to see for leaks.
Old Apr 3, 2021 | 12:00 PM
Lord_Eduard's Avatar
I didn't reset the battery because I didn't have time, but I did reset the codes. Today after driving around town for couple of miles, CEL did eventually pop out with cat error codes P0430 and 'pending' P0420), without MAF related. Maybe I did fry them after all, driving around with air intake leak...
Old Apr 3, 2021 | 12:07 PM
Cee Jay's Avatar
Have you had an injector problem in the past? An intake leak would lean the system, and cat problems usually come from too much fuel. I'd think still possible though.
My mechanic recommended CRC Catalytic Converter Cleaner, he said it works about 50% percent of the time but it's better than the other brands.
Maybe try some of that before you get crazy on other stuff?
Old Apr 3, 2021 | 12:22 PM
No I didn't, but then I own the car for less than a year. I tried injector cleaner last week, had the same logic regarding lean fuel trim. Noticed slight improvement in throttle response, but it's hard to tell whether is that placebo or not.
i could try with that cleaner too, before buying new cats. Is the full name 'CRC - Guaranteed To Pass'?
Old Apr 3, 2021 | 12:40 PM
Paulo Sérgio's Avatar
Just curious. What kind of tool are who using ...any special software for log analyse
Old Apr 3, 2021 | 02:00 PM
I tried OBD auto doctor, but now I'm sticking to Torque.
Old Apr 3, 2021 | 10:25 PM
gkubrak's Avatar
Like I said... you will probably have to replace your CATs soon due to the lean condition.
Good news is ... now you can get some hi flow cats and a x pipe to really let her rip!!
Or you can just ignore the codes like i've been doing LOL
Old Apr 4, 2021 | 11:14 AM
  #28
Originally Posted by gkubrak
like i said... You will probably have to replace your cats soon due to the lean condition.
Good news is ... Now you can get some hi flow cats and a x pipe to really let her rip!!
Or you can just ignore the codes like i've been doing lol
Gemma Whittle
Feb 25, 2020 08:25 PM
sharay38
Feb 3, 2020 05:30 PM
pinchas770
Aug 24, 2019 03:57 PM
knares
Jul 8, 2018 08:00 AM
Fermanaghman
Nov 15, 2012 09:01 AM
