Evoque Red Aluminum Paddles on XKR
Old Jan 4, 2021 | 01:51 AM
  #41
Stuart S's Avatar
https://www.jaguarforums.com/forum/x...nsions-192624/
The vendor I bought them from is no longer in business. You might be able to find them on Ebay. Just make sure they fit.
Old Jan 5, 2021 | 02:09 PM
  #42
DannyJ's Avatar
Originally Posted by Suneet Bajaj
Where did you get the extenders from?
try here https://www.ebay.com/itm/Gear-Steeri....m46890.l49292
Anyway, these are too long to me
Old Jan 5, 2021 | 08:03 PM
  #43
Stuart S's Avatar
That listing does not state that they fit the XK.
Old Jan 5, 2021 | 09:27 PM
  #44
jahummer's Avatar
JLR has not changed the standard plastic paddle design across ALL ranges of Jaguar and Land Rover models since they were introduced with the X150. Check your XJ and you will find they are the same as those on your XKR.
Old Jan 5, 2021 | 10:17 PM
  #45
ralphwg's Avatar
I have these installed in my '13 XKR. I find that the only issue with them is they are not bent towards the top. There should be a slight curvature to take your fingers away from the wiper and turn signal stalks when navigating a sharp curve or two in the twisties.
Old Jan 5, 2021 | 10:22 PM
  #46
Stuart S's Avatar
I'm just pointing out that the vendor doesn't list the XK.
That's good to know that the standard paddle design is the same across the JLR board ever since it was introduced with the X150.
And yes, I realize that the paddles are the same on my XKR and XJ, but they're 2009 and 2013 models, respectively. I don't know about the paddles on later years and other models, and I trust your expertise. Regardless, it's the buyer's responsibility to determine if aftermarket paddle extensions fit.
An enterprising X150 owner might be able to wrangle a free set of paddle extensions. Contact that vendor with a deal to inrease his market to include the 2007-2015 XKs. Ask him to send you a free set, and you'll try them on your XK, and send him detailed photos that they fit. If anyone does it, let us know.
indietor
Feb 10, 2018 05:49 PM
Lookout!
Jan 7, 2016 07:53 AM
powerhouse
Jul 25, 2014 07:05 AM
u102768
Feb 8, 2014 01:31 PM
