External Lighting Issue
Old Feb 23, 2013 | 05:43 AM
Pharri24's Avatar
Default External Lighting Issue
Hi
I hope I can find some help here with a lighting issue I have on my 2007 XK convertible.
During a journey home a couple of days ago I noticed the headlight warning lamp begin to flash, followed by message warnings saying my indicator lamp and brake lamp had failed.
Sure enough none of them were working. I replaced the headlight lamp, brake lamp and front indicator lamp but they still failed to function.
There seems to be an issue only affecting the RH side lighting circuit of the car (drivers side in the UK).
I'm hoping that someone here has experienced a similar problem or has any ideas of what to do next. I look forward to reading anything you can suggest.
Phil
Old Feb 23, 2013 | 02:38 PM
ralphwg's Avatar
Did you check your fuse(s) for those lights? They are probably all on the same fuse. Check your owner's manual for the fuse number and location. If you don't have the manual you can download one from this forum.
Old Feb 24, 2013 | 03:13 AM
Pharri24's Avatar
Yes, I thought of that and the only fuse that seemed to have any relevance was F31 that turned out to be fine.
Old Feb 24, 2013 | 07:53 AM
WhiteXKR's Avatar
Exterior lighting on left and right sides are on common fuses and are controlled by the computers in the central and auxiliary junction boxes.
It is possible one or more computers have crashed. Try disconecting the negative terminal of the battery for 10-15 seconds and then reconnecting it.
If that does not restore normal operation you need to get the fault codes read. For these types of codes, this needs to be done by the dealer or a Jag independent who has the proper equipment.
AutoEnginuity also sell a tool that can read these codes...but this is a $500 investment.
99xk8guy
Sep 29, 2025 10:51 PM
JarodL
Mar 7, 2024 01:39 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
King Charles
Sep 3, 2015 12:40 AM
OkieTim
Sep 2, 2015 12:48 PM
