External temperature saying -40°c
Old May 26, 2020 | 08:48 AM
pauledddy's Avatar
Originally Posted by Sean W
If you've done these tests as you mention Paul, you've done all you can do without SDD. And with SDD it appears you can only check the datalogger Temp sense voltage:
There's no separate module for the sensor. It feeds directly into the ECU
That's what I suspected, thats how i found out the pin to check on the harness. Guess I need to find someone local to me that has SDD!
Old May 26, 2020 | 08:49 AM
Sean W's Avatar
Old May 26, 2020 | 08:54 AM
pauledddy's Avatar
Yeah I checked pin 29 and pin 4 for continuity and they were both 0 resistance to the corresponding pin on the ambient sensor
Old Oct 21, 2020 | 11:43 AM
pauledddy's Avatar
Found out it was the fuse for the AIr Con (Fuse in the foot well on passenger side) had blown!
Connected to SDD and HVAC had red X, showing no connection!
Old Oct 21, 2020 | 12:55 PM
Stuart S's Avatar
Fortunately, it's a cheap and easy fix ... but now you have to determine what caused that fuse to blow. Or maybe not, and just keep some spare fuses available for when it blows again. And again.
Old Oct 22, 2020 | 01:59 AM
pauledddy's Avatar
The engine was out a few times, and the battery was replaced, jump started, etc.. since i found the fuse and replaced it, it has been fine! *touches wood*
Old Oct 22, 2020 | 09:27 AM
barnsie's Avatar
Deleted.
Old Oct 22, 2020 | 04:32 PM
  #28
guy's Avatar
guy
I've had the display show that temperature a few times... and it was that cold out.
wulfrun
Nov 20, 2018 05:18 PM
Steve.c3h8
Dec 28, 2017 12:00 PM
Anthony8858
Aug 18, 2016 12:31 PM
lazerbrains
Nov 29, 2011 11:22 AM
jackals
Jul 19, 2011 02:17 PM
