"Frozen" door syndrom
Old Jan 14, 2015 | 07:02 AM
8bit's Avatar
Default "Frozen" door syndrom
One for you guys in colder climates I guess. My 08 XKR has had door issues from time to time over the past few weeks, since the weather's been colder (around freezing point), I can't always get the driver's door to shut properly. It will open (but is stiff, think the glass sticks to the rubber seal when it gets cold) but when I pull the door shut it just makes a "bang" noise and doesn't latch shut.
I doubt it's the window failing to open the half inch or so to clear the roof as I observe it opening and can open and close it freely with the controls. The door catch will, eventually, free up and close properly again, sometimes needs a dose of WD40 to encourage it though.
Anyone got a more permanent fix for this?
Old Jan 14, 2015 | 07:21 AM
jimbov8's Avatar
3 in 1 do a fantastic silicone based lubricant that I use on all my electrical connections and mechanical latches. Also spray some on a rag and wipe it along the rubber seals.
Never had a problem and it has a nice citrusy aroma to it.
I get mine from RS components.
Hope this helps you out.
Jim
Old Jan 14, 2015 | 08:13 AM
8bit's Avatar
Thanks Jim. Have you had this specific issue and found that this keeps it at bay? I just ask because I've used WD40 a couple of times now and it still happens, hence I was thinking maybe I might need to change the door catch mechanism or something.
Old Jan 14, 2015 | 08:24 AM
jimbov8's Avatar
As of now I have had no problems with my car. I am a firm believer in preventative rather than reactive maintenance and the 3 in 1 stuff is just one part of my arsenal in keeping my car trouble free.
WD40 as well as being a lubricant is mainly a water dispersant and will erode quite quickly. The 3 in 1, when dry, will leave a film that will last much longer and keep your mechanical bits moving the way they should.
Old Jan 14, 2015 | 08:28 AM
andys-GR's Avatar
I'm having the same issue, when cold the latch freezes so on the first close the bounces and only latches on the safety. It then needs a second harder swing to latch fully. Its on my list of issues for the dealer to look at. I''l let you know what they say / do.
Old Jan 14, 2015 | 08:46 AM
mosesbotbol's Avatar
Heat gun and extension cord... Heat door until latch works. Happened to me all the time.
Old Jan 14, 2015 | 09:55 AM
Mikey's Avatar
Then lubricate it with a suitable product (NOT WD40!) so it stops reoccurring.
I use a light silicone based product that leaves a film. WD40 is not suitable for any such application as it is NOT a permanent lubricant.
Old Jan 14, 2015 | 10:07 AM
8bit's Avatar
OK thanks, I've got some silicone lubricant (originally bought to cure slow-to-retract seatbelts on a previous car) which should work, I'll try that.
Old Jan 14, 2015 | 10:43 AM
Scottsgreenjag's Avatar
From: Somewhere south of Grand Rapids, Michigan, USA
Had the same issue with my old Corvette. You got some good advice above. Stay away from WD-40 as it is a water dispursment product. I too had good luck spraying a silicone product on to a cloth and wiping my gaskets. A lock graphite spray or liquid on the latch mechanism might help. Doesn't seem to bind up like an oil/grease product
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
kevinl
Oct 31, 2019 06:15 PM
al_roethlisberger
Sep 21, 2015 08:07 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
