Fuse for front foglights.
Old Sep 19, 2018 | 12:00 PM
peterv8's Avatar
Default Fuse for front foglights.
I can't find in the manual where the fuse is for the front foglights. I failed MOT because I have drl led foglights. If I pull the fuse and the foglights don't work when they push the button it's okay.
Old Sep 20, 2018 | 06:11 PM
NBCat's Avatar
It would certainly be helpful to know the MY of the vehicle.
Here is the Electrical Guide for vehicles with early build VINs.
Old Sep 21, 2018 | 12:51 AM
peterv8's Avatar
It's an 2006, thanks for the guide but have looked in it and there doesn't seem to be a specific fuse for them!?
Old Sep 21, 2018 | 02:38 AM
You won't find a fuse.
The Front Fog Lights are protected by the CJB (Central Junction Box). The circuit is protected by FET's (Field Effect Transistors). which can detect overloads and short circuits.
The FET's respond to heat generated by increased current flow caused by a short circuit. On a normal circuit this would cause the fuse to blow. The FET's disconnect the power supply to the affected circuit. When the fault is rectified or the FET has cooled, the FET will reset and operate the circuit normally. If the fault persists the FET will cycle, disconnecting and reconnecting the power supply.
The CJB stores fault codes which can be retrieved using Jaguar SDD.
Alan55
Aug 27, 2013 02:13 PM
Thermo
Jul 10, 2013 05:49 PM
Davebc
Sep 23, 2012 07:55 AM
Mafioso
Oct 29, 2010 02:01 PM
wnlewis
XJ40 ( XJ81 )
Feb 9, 2009 10:47 PM
