Headlight Replacement Bulbs
Old Feb 20, 2023 | 12:15 AM
  #41
Juss's Avatar
I tried LED brake lights also. Even though they worked well, my car kept telling me that my brake lights had failed, so I've swapped them back.
Old Feb 20, 2023 | 06:28 AM
  #42
Mjyfly's Avatar
Default Headlight refurb
How did you refurb the exterior of these headlights please?
Also like the look of replacement bulbs. Must be better than my 15 year old glow worms.
Old Feb 20, 2023 | 10:45 AM
  #43
Juss's Avatar
I didn't refurb the exteriors. They're pretty clear and don't need anything.
Old Feb 20, 2023 | 01:01 PM
  #44
Cee Jay's Avatar
My outer housings are nice and clear, but the inside lenses are a bit cloudy. I did tint the outsides with 10% grey, but also used some expensive-ish LED bulbs. The light is now more than enough, even through the cloudy and tinted units.
Old Feb 20, 2023 | 07:18 PM
  #45
Brewtech's Avatar
try to find a set that is coded for use in cars with voltage sensors. The previous owner installed LED tails but that’s a different kind of install.
Old Feb 20, 2023 | 10:19 PM
  #46
kj07xk's Avatar
Do you recall what LEDs you used? I found a post where you put some powerful ones your truck. Did you use the same in your car?
Old Feb 20, 2023 | 10:26 PM
  #47
Cee Jay's Avatar
I seriously do not remember which ones, but they were not the same. I wanted to try some better ones in the XKR. I used HIKARI bulbs in one or the other. Can't remember which. I'll look in my garages, see if I can find the old box.
EDIT:
Well, ****. I guess I'm an old forgetful coot.
I used the HIKARI LED 6000k in my old F150.
I found in Amazon where I bought some brand RCP 6000k Xenon bulbs in D1S, so I evidently cheaped-out on my Jag to the tune of $26 for the set. Still though, they are a lot brighter than the ones that were in when I bought it in 2014, which I expect would be the original OEM bulbs.
Old Mar 4, 2023 | 11:11 AM
  #48
Mjyfly's Avatar
Matt, the difference between those two headlamps, before and after, is terrific. Can you explain the process you used to get to that perfection please? Did you take the units off the car first and if so how? You will gather that I am not an experienced mechanic!
Old Mar 4, 2023 | 05:59 PM
  #49
JackJohn's Avatar
Each lamp assy is held in place by three bolts. Two are under the hood (bonnet) and one is in the wheel well. (Turn the wheels all the way left to get to the right light and all the way right to get to the left light.) There is a wire bundle and a water line (cleaning) attached to each.
VTGBoss
Feb 16, 2023 10:00 PM
jagent
May 3, 2019 08:43 PM
ian20x
Jun 28, 2018 04:54 AM
91stealthes
Nov 10, 2014 08:26 PM
cyberice
Jan 18, 2014 11:07 AM
