Headlight Washer Fuse
Old Apr 14, 2024 | 03:51 PM
sailor's Avatar
Default Headlight Washer Fuse
Graham, I too have a screenwash pump problem on my X150 2012 XKR and the first thing I want to do is check the Screenwash pump fuse. I can only find one fuse F4 for Powerwash. I assume that must do both windscreen and headlamp?
Old Apr 19, 2024 | 03:35 AM
Glen,
I can only see one fuse for the wash/wipe system. If both windscreen and headlamp washer pumps are off, it's likely to be the fuse although the headlamp wash does also go through a relay. If only one is off, it's likely to be the pump itself failed.
Colin21958
Mar 25, 2022 10:36 AM
Rod Terra
Jun 14, 2020 04:28 AM
Johnken
Jan 14, 2018 11:19 AM
Carpn
Sep 14, 2017 08:33 PM
RogB
Oct 28, 2014 01:53 PM
