help on my 2008 XK
Old Jul 15, 2017 | 10:49 AM
cj005's Avatar
Cool help on my 2008 XK
driving along starts to miss and lose power would not idle. towed it home
after an hour started right up and purred like its supposed to. fuel filter???
29k miles first time with any issue. ????? thanks
Old Jul 15, 2017 | 11:08 AM
Sean W's Avatar
hey cj005, guessing is not our thing really, at least without some error codes to go by. Please identify the DTC's and get back to us.
Old Jul 15, 2017 | 03:14 PM
cj005's Avatar
Cool
obd plug drivers side under the dash ?
Old Jul 15, 2017 | 04:08 PM
Sean W's Avatar
yes on the left
Old Jul 17, 2017 | 03:32 PM
cj005's Avatar
7e8 generic fuel pump control circuit open ?
Old Jul 17, 2017 | 03:34 PM
mosesbotbol's Avatar
Gas cap issue?
Old Jul 17, 2017 | 03:40 PM
cj005's Avatar
Cool
7e8 generic fuel pump a control circuit open
Old Jul 17, 2017 | 03:53 PM
cj005's Avatar
Cool
gas cap seems ok
Old Jul 17, 2017 | 04:40 PM
davchr's Avatar
I don't think 7e8 is a legitimate Jaguar OBD code. If you are using a simple reader it will display only PXXXX codes - the letter "P" followed by four digits. That is what you are looking for.
If you have a sophisticated reader if might display BXXXX - body codes, CXXXX - chassis codes, or UXXXX codes - network codes.
I believe some readers will spit out HEX equivalents of the numeric P code. 7E8 HEX = 2024 which would be P2024 Jaguar Evaporative Emissions (EVAP) Fuel Vapor Temperature Sensor Circuit. I don't think that would affect the driveability of the car.
Try a different reader and see if you can get a real PXXXX code.
Old Jul 18, 2017 | 12:42 AM
michaelodonnell123's Avatar
Start with a fresh tank of premium fuel and give it the old Italian Tune-up (drive it fast and hard) is my suggestion. You might have water in the gas tank or dirty fuel.
Old Jul 19, 2017 | 10:22 AM
LoudHogRider's Avatar
I had no idea I was Italian...
Old Jul 19, 2017 | 03:13 PM
Sean W's Avatar
Or get a real code readout.
Old Jul 20, 2017 | 06:41 AM
JagV8's Avatar
Get a proper code. A few $$$
Old Jul 21, 2017 | 05:35 AM
1 of 19's Avatar
Yeah I thought I was mostly Irish, guess not!
Old Jul 23, 2017 | 06:38 PM
Rey's Avatar
Rey
Gradual loss of power, no idle and then recovery after car sits for a while. Not so sure it is a fuel issue.
Sounds more like an electrical issue, where ignition etc. draw more than the alternator and battery can handle at low rpm. At higher rpm the alternator adds enough power. Then at rest the battery recovers some of its lost charge.
Wonder if you are using the original OEM battery at 29K miles? Consider changing any battery over four years old.
Old Jul 23, 2017 | 10:06 PM
Stuart S's Avatar
Many national auto parts stores (Pep Boys, Auto Zone, etc.) will read codes for free.
Old Jul 25, 2017 | 11:58 AM
cj005's Avatar
Cool
used a snap on reader code is p0087 ?
Old Jul 25, 2017 | 03:03 PM
Sean W's Avatar
That's a generic code, not jag specific. There may be more codes specific to Jag but with a generic reader you won't see them.
You don't elaborate much so it's hard to know if you intend to take it to a shop or DIY. Here's some info on P0087 that should get you going.
https://www.yourmechanic.com/article...pencer-clayton
Old Jul 25, 2017 | 03:27 PM
cj005's Avatar
Cool
what should the fuel pressure be at the rail ?
ill change the fuel filter regardless and pull a code
if still low regulator next
some parts info would be good Jag wants to much for parts
thnx
Old Jul 25, 2017 | 03:32 PM
Tervuren's Avatar
If it hasn't been done, based on time, your fuel filter would have come up in the Jaguar's service schedule. Seven years is the non mileage trigger in the schedule. Your 2008 would have been scheduled for 2015 regardless of mileage. I've never taken apart a fuel filter to know why it should be done based on time, but this may be a part of your problem.
