High Engine Temp Warning 07 XK
Old Jun 14, 2021 | 09:00 AM
Stuart S's Avatar
Originally Posted by Kuekuatsu07
... Now it has a leaking radiator and the Behr units run around $700. ... Dreaming of an aftermarket solution that’s either cheap like a CSF radiator or an all metal radiator that is worth $700 plus.
Any ideas or creative mods to an XJ or XF radiator are welcome if anyone knows any, I am all ears. Miss driving my DAILY DRIVER XK.
2007 XK 4.2 NA
170k plus miles
Your radiator might be repairable depending on where it's leaking. Google "radiator repair shop Birmingham AL" and call them.
Old Jun 14, 2021 | 11:24 AM
Kuekuatsu07's Avatar
Default Radiator tank on outlet side
It looks to be leaking between the tank and core near the outlet side, right hand side top of the radiator. Been driving short trips and loosening the overflow tank cap whenever I arrive, relaxing the pressure on the system so it doesn’t leak out so fast under pressure.
I didn’t know plastic tank radiators could be messed with. Most gas tank shops do metal radiators an gas tanks for sure.
Guess I should not complain, but I’m scraping by here lately like most of us on this planet at this point.
2007 XK NA 4.2
Old Jun 14, 2021 | 02:04 PM
kj07xk's Avatar
Could switch to a ‘waterless coolant’ to reduce the pressure, but not a cheap solution either, and you’d still have some leakage.
rts1021
Aug 31, 2023 10:34 AM
bigdhenderson
Nov 24, 2020 03:20 PM
bocatrip
Apr 28, 2014 12:44 PM
pab
Oct 23, 2013 10:41 AM
Hennie
Jan 20, 2013 02:23 PM
