Hiss/cough sound when accelerator is tapped
Old Sep 14, 2022 | 11:33 PM
aafattore's Avatar
Default Hiss/cough sound when accelerator is tapped
Hi, I have a 2013 XK 68k miles. Got the limited performance light while exiting the highway. Car ran rough at the stop light and smelled gas. About 30 seconds later, gas smell went away, light went off and car ran normal. Pulled codes P300, P302, P304 & P306 which are misfires. Changed the spark plug and coils, started the car. Noticing a short hiss coming from the front of the throttle body when the accelerator is tapped. Any idea what this could be? I'm assuming a leak but nothing visibly cracked or worn.
File Type: mpeg
Old Sep 15, 2022 | 06:22 AM
guy's Avatar
guy
Doubt changing all the spark plugs and coils had any significant effect.
How did the plugs look?
Definitely a leak.
Old Sep 15, 2022 | 01:23 PM
jahummer's Avatar
Something broken when removed or reassembled. If it’s intake related you’ll
like get a lean code. I’d begin removing and or inspecting any hoses or instakes and then reassemble. The throttle body hoses and breathers need to be firmly seated or they may hiss.
Old Sep 16, 2022 | 09:32 AM
aafattore's Avatar
Definitely a leak.
The plugs were dirty but not horrible. I agree with it's likely a leak. Now we just have to find it!
LaMonica1972
Aug 20, 2021 09:44 AM
StormtrooperFtype
Dec 14, 2018 12:30 PM
DavidXF
Oct 10, 2018 01:37 PM
LRL2002JaguarXtype
Mar 30, 2012 07:21 PM
Humy
Apr 12, 2007 02:26 PM
