how to disconnect vacuum fitting?
Old Apr 15, 2023 | 12:41 PM
racerxf12004's Avatar
Default how to disconnect vacuum fitting?
Hi guys. I'm trying to disconnect the 2 vacuum fittings on the passenger side of the supercharger. (the tube at the top of the photo is supposed to be under the vacuum fittings not above it) I can't figure out how to remove them and I don't want to break them. There's 2 tabs 180 degrees apart from each other. Do I push both of them in at the same time? Thanks in advance for anyone's help. This board has been great.
Old Apr 15, 2023 | 02:09 PM
Tracee's Avatar
Yes, just push both tabs in - fitting should release O/K...
Old Apr 15, 2023 | 03:10 PM
jahummer's Avatar
Those are actually intercooler coolant lines so prepare for escaping coolant. I've a special tool I use but small fingers can work too.
Old Apr 15, 2023 | 03:57 PM
Got them both off and found out their coolant lines. Thanks for the help ppl.
Old Apr 15, 2023 | 04:43 PM
jahummer's Avatar
Glad you figured it out. I said they were coolant lines in post #3.
Treozen
E type ( XK-E )
Oct 16, 2020 06:08 PM
scottatl
Jul 31, 2019 12:02 PM
neinz
Jul 29, 2017 03:46 PM
patpin
Sep 22, 2014 12:05 PM
