How to keep your baby cool
The undertrays are critical for maintaining proper engine compartment air flow. The engine cover's merely decorative, in fact the RS GT didn't even come with one.
So no boil over at 230 F but still a good point to start moving toward cooling the engine down.
I have also, but I still think it's for hood protection and also 'appearance'.
1 So many issues, see other posts...please point to a few that you feel are relevant
2 If in doubt, if it was superior...factories weight many factors and come to a 'somewhat' balanced acceptable set of compromises. One of which is cost another is the freeze point.
I do not use it in my current vehicles but I have used it in several aluminum engines over the years that ran way too hot in Texas. Typically they all ran @ 10~12 degrees (f) cooler after switching and I never had any 'issues' due to using it.
Racers on many tracks in Texas, that had heat issues, use water wetter to keep things 'cooler'.
If I had a serious issue with heat, depending on the location where the vehicle was driven I would consider Redline Water Wetter, or VP's Stay Frosty, based on my experiences.
ymmv
wj
What evidence do you have to suggest that? Its the number one choice for track enthusiasts as it runs cooler AND has if theres a spill it doesnt cause any safety problems on the track. Thiss as a replacement for coolant not as an additive.
Forgive me, I would like to pull that statement apart a bit.
ymmv
wj
ymmv
wj
Too late. You'll be in serious trouble if you wait for the car to tell you something is wrong.
KittyVet
May 31, 2020 11:57 AM
