How many brake pad sensors for XKR
Old Apr 1, 2021 | 09:02 PM
UKWyldcat's Avatar
Default How many brake pad sensors for XKR
2010 XKR. Trying to order new brake pads but need to know does each wheel have a brake sensor, or is it just front left/right or rear left/right? Thanks.
Andy
Old Apr 1, 2021 | 09:06 PM
DGL's Avatar
DGL
There is only 1 on the rear and 1 on the front. I forget which side. If you do a search on this forum I'm sure you will find the answer letting you know which side.
Old Apr 1, 2021 | 09:16 PM
OzXFR's Avatar
Odds on to be the same as the 2010 XJ and XF and pretty much every Jag ever since - left front and right rear, inner pad only on both.
Old Apr 1, 2021 | 09:19 PM
UKWyldcat's Avatar
Thank you both...
Old Apr 2, 2021 | 02:53 AM
I could have guessed but I checked the Workshop Manual:
...... The inboard brake pad of the LH front brake incorporates a wear sensor. The brake pad wear sensor is wired in series with a wear sensor on the RH rear brake .....
chazaroo
Oct 18, 2019 02:55 AM
Supercharged Jag
Nov 30, 2018 12:01 AM
jimjar70
Oct 21, 2018 04:22 AM
jeffkerr
Mar 7, 2015 04:07 PM
jmalynne
Feb 15, 2015 01:07 PM
