Injector size on 4.2SC ? E85 Ethenol fuel anyone, flex fuel kit?
Old Jun 4, 2020 | 11:34 AM
XJR-99's Avatar
I has been said that the later red 4.2 injectors flow a bit ( 5-10% ) more than the early ones. I had 590cc , but the new ones are 860cc...new set-up simulation shows ~800bhp. Difference between 93 + water/methanol vs E85 is just about 20bhp. Pump E85 used to be 70-80% ethanol.
Old Jun 4, 2020 | 02:06 PM
AlexJag's Avatar
Sponsor
Xjr99 so you don't think 506cc number is correct?
Which ones flowed 590?
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Jun 4, 2020 | 02:18 PM
XJR-99's Avatar
I have not flowed stock 4.2 injectors. What's your base fuel pressure? You should see it through ECU.
Old Jun 4, 2020 | 02:43 PM
AlexJag's Avatar
Sponsor
55psi
__________________
Old Jun 5, 2020 | 01:13 AM
avos's Avatar
The 4.2 SC engine (so from the Pan Pag ECU, mostly from 2006), is using higher flow injectors, and are colored brownish, compared to the blue ones from before. When I measured them they flowed about 480cc at 55psi, but considering my Chinese flow unit, it may be off somewhat. So 506 certainly does sound right.
Old Jun 5, 2020 | 01:51 AM
avos's Avatar
@XJR-99
Thanks for your pioneering on the E85 and sharing the info, that has given me some confidence that to do it as well on my car (one day) I feel pretty confident with the unit you have used that it will workout.
Old Jun 5, 2020 | 02:40 AM
AlexJag's Avatar
Sponsor
Thanks for confirming! So there is definitely some room to play with.
__________________
Old Jun 5, 2020 | 02:54 AM
  #28
AlexJag's Avatar
Sponsor
Originally Posted by jahummer
I have a Snow meth kit. While it does allow room to tune a bit more power it is more about managing IATs and heatsoak, helping maintain consistent power rather than creating more.
I am at the point where more power is going to start costing big $$$$ so considering a less costly option, nitrous somewhere between 50 shot and 100 shot.
Speaking of power. Don't think it's ever been done on our cars, I wonder
​​​​what properly built headers could gain...
__________________
Old Jun 5, 2020 | 08:19 AM
JagV8's Avatar
As lots more power was gained using a TS then the headers look good enough.
Old Jun 5, 2020 | 10:40 AM
  #30
jazzyjags's Avatar
I think Caldoofy had a nice set of custom headers for the 4.2 R. Not sure if its the same size and pattern for your updated 4.2 engine. But he had some decent gains even without tuning for it. If i remember correctly it was leaning out on the high end of the rev range though. I'm sure with a good tune, those headers would be a nice addition.
Old Jun 5, 2020 | 11:12 AM
  #31
jahummer's Avatar
VAP went through the effort of making 5 litre headers and saw no gains. Also many comments elsewhere with attempts at replacing the logs on the 4.2 without seeing any benefit. I have long wanted to do this so if someone can prove it's worth the effort I am ready...
Old Jun 5, 2020 | 01:51 PM
  #32
Cee Jay's Avatar
Frikken Jag made some custom headers for the 4.2, but I don't think he had any takers. They were pretty but quite pricey.
He is/was a member of this forum. Maybe hit him up?
Old Jun 5, 2020 | 04:55 PM
  #33
AlexJag's Avatar
Sponsor
Im only dealing with FrickenJag again if he makes it right on my high flow cats that I purchased from him which failed under 7k miles , he was using cheap MagnaFlow units... They started separating inside as soon as a got them
__________________
Old Jun 6, 2020 | 03:26 AM
  #34
MarkyUK's Avatar
I've had custom made headers on other cars by these peeps:
https://www.haywardandscott.com/jaguar.html
Both cars were forced induction but were hampered by the catalyst set up somewhat, as all of these were owned pre 2014 (when it became a legal requirement to have cats fitted in the UK) I just used a by-pass pipe. With an XKR I'd only consider a modified header/manifold/down-pipe with racing cats and then only from a company that could flow-test them.
I've no plans to do this to my current R until the existing cats fail, if they don't it'll stay as is
NCJagman
Apr 14, 2018 08:30 AM
new mexico
Jul 6, 2017 04:28 PM
jaguarcraver
Nov 6, 2013 03:42 PM
Ixlr8
Sep 29, 2010 02:11 AM
super_jag
Apr 16, 2009 01:26 PM
