Jaguar XK X150 2006. Battery drain issue
Old Jan 28, 2024 | 08:54 AM
JBF's Avatar
JBF
Originally Posted by Tiepolo
I was to it last summer and then I was told you can brick your car...So I didn't do so.
It need a specific windows computer (just have Macs around) , a specific cable and even though you can brick the car..
Not in a mood to brick my car.
There must be third party diagnostic tools available to do basic alterations on jag's.
Old Jan 28, 2024 | 08:51 PM
guy's Avatar
guy
Many of us use SDD. The. “General Tech Forum” contains some stickies which outline the process for setup.
This being said, SDD is not intuitive. And a wrong move can result in a bad day.
Old Aug 29, 2025 | 11:37 AM
Excalibur2012's Avatar
Have you done any troubleshooting ? Ammeter on negative side ? Would rather you used a battery minder in the meantime to keep it charged than disconnecting it..These aren't 60's or 70"s vehicles.
Old Aug 29, 2025 | 01:19 PM
Tracee's Avatar
Do not fear SDD - but respect it...
Old Sep 1, 2025 | 01:16 PM
Agree with Guy about this disconnect as a solution. Think you're just asking for more trouble. Either you have a problem that needs to be found or it is normal light drain. These aren't xk120's or XJ6's These modern vehicles, regardless of make, need to either be driven or when not for days, weeks or months, to be on 'Minders" not chargers. A good battery kept in a charged state prevents headaches !
Old Sep 1, 2025 | 02:52 PM
Bill400's Avatar
Default It's the battery!
It's the battery!
I REALLY disliked the "It's the battery chorus.
However, having experienced two poor performing new batteries (different Jaguars), I have become a believer.
I always check date codes when shopping for a new battery and have walked away when the date was more than the previous month.
Still, I got poor (but acceptable, according to the dealer) batteries on occasion.
I did, finally, manage to get a warranty replacement on one. It made a world of difference.
Monitoring system/battery voltage with a cigar lighter voltmeter works well for me.
Normal system charging between 13.5 and 14.5V, depending on circumstances.
Ignition off battery voltage typically 13-12.9 volts. Steadily decays to 12.6V where it hovers until dropping to 12.5V or timing out.
If monitoring by voltmeter suggests a problem after ignition off, a simple battery test is to pull the battery, charge the battery on the bench (not concrete floor) to 13V. (12.6V + surface charge).
Remove charger and let the battery rest. Monitor the voltage decay. If after 24 hours the voltage is less than 12.6V get a new battery.
Mjyfly
Sep 6, 2025 09:49 PM
M1redskin
Jun 15, 2023 12:09 PM
rflorey
Oct 17, 2022 01:42 PM
DocBottster
XJ40 ( XJ81 )
Jan 6, 2022 04:05 PM
YycXJS
Oct 9, 2013 07:24 AM
