Just the ball Joint please!!!
Old Apr 22, 2016 | 02:42 PM
ryanbanks's Avatar
Default Just the ball Joint please!!!
I have a 2008 xkr portfollio. The passenger rear upper ball joint is bad. I want to press it out and replace with a new one. I can not find the replacement for it. Please help! Dealer only sells the control arm. This is my first post ever so I am hopeful this works. Thank you.
Ryan
Old Apr 22, 2016 | 06:01 PM
Sean W's Avatar
No such luck. You need to buy the whole control arm. The good news is that they are relatively cheap. Cheaper still if you're a DIYer.
Jag# C2P 13877 $200
Ford 6W4Z-5500-AA or AB $175
Old Apr 22, 2016 | 06:43 PM
NBCat's Avatar
You may also able to find one made by an OEM supplier that supplied the original part to Jaguar, but at a much lower price.
Old Apr 22, 2016 | 06:50 PM
Sean W's Avatar
OEM would be Lemforder
about $230 on eBay
Old May 23, 2016 | 10:15 PM
ryanbanks's Avatar
Thank you guys. I purchased the whole control arm.
Old Jul 15, 2017 | 05:03 PM
jahummer's Avatar
Jag# C2P13877 $200
I'm seeing part number C2Z31679 has replaced the above part number and is now $339!!!! Anyone know what was changed for the new part number? All I need is the ball joint since I am doing a poly conversion.
Chuck Schexnayder
Feb 28, 2021 10:27 PM
EZDriver
Mar 1, 2017 02:02 PM
Gus
Sep 1, 2016 09:47 PM
dstjohn
Apr 16, 2016 05:38 PM
Tomica
Mar 31, 2016 08:33 AM
